Thread: Can caps blow |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 453 Registered: Jul-07
| Posted on Monday, October 22, 2007 - 02:31 pm: |
ok the other day I stopped to pick my cousin up and when I started the car back up the radio won't make any sound I checked the cap and theres nothing could the cap go out |
Silver Member Username: Santa_fe
Post Number: 292 Registered: Jul-07
| Posted on Monday, October 22, 2007 - 07:15 pm: |
umm first check all grounds....possilby a loose connection behind the radio, not sure on the cap thing...mabey with to much juice but it would have to be alot really fast i think |
Gold Member Username: Freezeman_7
FOR SALE,
BNIB RD AUDI...
Post Number: 2027 Registered: May-06
| Posted on Monday, October 22, 2007 - 07:22 pm: |
ehh it should still send power the connections, i would think anyways, check all connections and ur rcas |
New member Username: Jjproductions
Post Number: 9 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 07:34 pm: |
About the question in the topic title... anything will blow if you put enough power through it. Maybe your radio just died? Did you try a CD perhaps? BTW by cap do you mean capacitor or something covering a connection or what? A cap could be many things. |
Post Number: 295 Registered: Jul-07
| Posted on Monday, October 22, 2007 - 07:42 pm: |
jeffy boy...on herer cap always means capactitor lolz |
Bronze Member Username: Jjproductions
Post Number: 12 Registered: Oct-07
| Posted on Monday, October 22, 2007 - 07:49 pm: |
Thanks Santa-Fe. But still... maybe a crappy radio is the fault? Why do you instantly blame it on the cap? Check your wiring and everything. If you modified anything recently, you may want to recheck everything. |
FOR SALE,
BNIB RD AUDI...
Post Number: 2028 Registered: May-06
| Posted on Monday, October 22, 2007 - 08:08 pm: |
what im sayin is a cap could blow? sure why not> but the copper connectors dont have a fuse and should still send current. |
Post Number: 296 Registered: Jul-07
| Posted on Monday, October 22, 2007 - 09:27 pm: |
yea thats tru chase...huh id still say it sounds like a ground problem to me....lol np jeff welcome to ecoustics |
Louisville,
Ky
Post Number: 454 Registered: Jul-07
| Posted on Tuesday, October 23, 2007 - 11:00 pm: |
alright you all thinks i willl have to wait for it to stop raining be 4 i can check anything |
Silver Member Username: Cblaze
Tn
Us
Post Number: 250 Registered: Sep-07
| Posted on Wednesday, October 24, 2007 - 01:33 am: |
i heard caps will blow but u will know it when they do,they can explode according to some ppl |
Louisville,
Ky
Post Number: 455 Registered: Jul-07
| Posted on Wednesday, October 24, 2007 - 02:21 pm: |
well no explosion in my tunk atleast not that i remeber lol but still i think i founf the problem i think the preouts on my radio went out is that possible and will pioneer cover it in the warranty and repair it |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5438 Registered: Jul-06
| Posted on Wednesday, October 24, 2007 - 03:39 pm: |
Use a multi meter on the wires before and after the capacitor.Check your grounds. |
Louisville,
Ky
Post Number: 456 Registered: Jul-07
| Posted on Wednesday, October 24, 2007 - 11:35 pm: |
all the grounda are perfect its not like this was a new install i had everything already installed and then it quit |
Gold Member Username: Drivingreckless
DD 9515f,
148.2 db Mov...
Post Number: 4437 Registered: Apr-06
| Posted on Thursday, October 25, 2007 - 01:04 pm: |
i know lil robs mom can blow!!! |
Louisville,
Ky
Post Number: 459 Registered: Jul-07
| Posted on Friday, October 26, 2007 - 12:45 am: |
ok yall its fixed but theres a new problem that cam up sum how i got some electrical interferance and now i can hear the alt like it was riding right next to me any soultions yall can think of |
Silver Member Username: Imi4tth3w
San Antonio,
Texas
Post Number: 121 Registered: Feb-07
| Posted on Friday, October 26, 2007 - 10:11 am: |
run the rca's away from the battery cables? |
Louisville,
Ky
Post Number: 460 Registered: Jul-07
| Posted on Friday, October 26, 2007 - 10:43 pm: |
yeah there far from each other i thing i am just going to give in and redo the whole trunk so i can make sure i am away from all power cables and that i can rule the trunk out |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 2959 Registered: Mar-06
| Posted on Friday, October 26, 2007 - 11:25 pm: |
re do the ground wires where ever it goes. in the trunk, under the hood, in the dash for hu. on the cap. One of the grounds has gone south. |
Boston South,
MA
Post Number: 2960 Registered: Mar-06
| Posted on Friday, October 26, 2007 - 11:27 pm: |
And just to add, running power next to rca's DOES NOT, I repeat, DOES NOT CAUSE NOISE. Poor installation practice is the root of noise. |
Louisville,
Ky
Post Number: 465 Registered: Jul-07
| Posted on Saturday, October 27, 2007 - 01:30 am: |
alright marc thanks all the grounds are going to be re done 2marow while i wait on my new windshield some idiots cracked it |
