Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > Speaker RMS
Author Thread: Speaker RMS
Username: Gnya96792102
Hi I have Pioneer Coaxials RMS Power Handling 35 watts
Peak Power Handling 220 watts
Impedance 4 ohms
What is the result if i use a MTX amp (MTX Audio XThunder 502X
) powering 50 watts rms to each speaker
URL For Amp: http://www.sonicelectronix.com/item_9034_MTX+Audio+XThunder+502X.html
Url For Coaxils:
http://www.sonicelectronix.com/item_8342_Pioneer+TS-A1672R.html
Relevant Product Info
Or Should I Just Run It Off My head Unit Running 50W Peak 18 RMS
Username: Adddisorder
Palm Beach, Florida
Post Number: 5346
you will be fine, just set your gain right so you wont be sending a clipped signal to your amp. and so you know their is no reason for your other thread.
Post Number: 7
Thanks alot
Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > Speaker RMS [ « Previous ] [ Next » ]
