Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Do i need a isolator
Author Thread: Do i need a isolator
Username: Talon01
12 audioque 2.5 144.9 ..., Pa
Usa
Post Number: 216
for a kinetik 1400
Username: Glasswolf
Wisteria, Lane
Post Number: 12064
if you plan to run two batteries, yes use a battery isolator.
Username: Nd4spd18
Northwest PA
Post Number: 3427
^^^^^ what he said
Remember than having 2 batteries isolated with not help your electrical system any, it only helps when you play the system with the engine off.
You only need one battery if you only play it with the engine on.
Username: Th3pwn3r
Post Number:...
Post Number: 5383
"You only need one battery if you only play it with the engine on."
That's somewhat true but it depends on what your batteries are charged up to voltage wise.
Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Do i need a isolator [ « Previous ] [ Next » ]
