Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp settings for 2x 12" kicker comp v...
Author Thread: Amp settings for 2x 12" kicker comp vr's..
Username: Crafthell
I'm currently Running a CRUNCH 800watt amp with 2x 12" Dual 4 ohm CVR's wired for mono 4ohm bridge (400watt x 2 subs) so far it runs good but what should i be putting the LEVEL, BASS EQ, LP FILTER, and last HP FILTER settings at for KiCKER CVR's
Crunch PZi 125.4 Amplifier Specifications:
* RMS @ 4-Ohms: 125W x 4-Ch
* RMS @ 2-Ohms: 200W x 4-Ch
* RMS @ 4-Ohms: 400W x 2-Ch
* Dynamic Music Watts
* SEPP A/B-Class PZi Amplifier Designs
* Bridgeable Design
* s Illuminated, Large New Design Crunch Logo
* PZi. MOSFET Pulse Wave Modulated Power Supply For Instant Maxx Current Output
* 2-Ohm Capable A/B Class
* Config to 3-Ch R & L and Sub Mode
* Rugged MOSFET Audio Outputs
* PZi Amp Protection with System Diagnostics LED's That Protects Against:
o Current / Amperage Overload
o Short Circuits
o Thermal Overload
o DC Offset
* Hi-Level Speaker Lead Inputs
* Silver Preamp Level RCA Inputs
* Daisy Chain Line Outputs
* Versa Cross™ Sound Shaping Controls:
o Mono/Stereo Switch
o HP/LP/Full-Pass Freq. Selections
o Crossover Frequency Adjustments: 60 Hz to 1.2kHz
o (30 Hz to 250 Hz Low-Pass)
* Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz
* Input Level Control (0.2 to 5V)
* Oversized Speaker Terminals[/code]
2x Kicker 07CVR12-4 Subwoofer Specifications:
* Sensitivity: 86.7 dB
* RMS Power Range : 400 Watts
* Peak Power Handling: 800 Watts
* Impedance: Dual 4 Ohm
* Low Frequency response: 25 Hz
* High Frequency Response: 500 Hz
* Diameter: 12 Inch
* Santoprene surround on the edges
* Injection-molded polypropylene cone
* Aluminized coating
* Stamped-steel basket with perimeter venting
* Spiralead tinsel-lead technology
* Polyamide high-temp former
* Dual, high-temp (428 degrees F) voice-coil wire
* Polycotton spider for improved linearity at high volumes
* Progressive-roll
Thanks, Craft
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4966
hifonics Bxi 1206D for you
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 162
you have an amp that pushes a *rated* 400wrms, consider upgrading the amp if you want the cvrs to reach their potential.
800 + wrms depends on amp.
Username: Crafthell
k thanks for the input so theres really no way i could blow these subs with this amp? but u didn't answer my question what settings can i set the amp at?
i already bought that amp for 89$ new and the 2x kickers @ 155$ total... if need be ill upgrade amp later but they are pretty damn loud even if it doesn't push a total of 800 watt.. i turn it past 4 on most songs on the head unit and my head hurts lol.. and i think it goes to 30-40
Username: Crafthell
i found the:
Hifonics BXi 1206D
2400-Watt Brutus Mono Amplifier
for $234 @ onlinecarstereo.com (63% off retail)
if i buy this amp what settings can i put it at?}
Username: •cam•
Post Number: 837
http://www.subwoofertools.com/forum/setgain.asp
how to set your gains.
Set the cross over where you like.
No bass boost.
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp settings for 2x 12" kicker comp v... [ « Previous ] [ Next » ]
