Thread: Big 3 cherokee |
Silver Member Username: Talon_es93
Trinidad,
Co
Post Number: 699 Registered: Mar-06
| Posted on Thursday, October 11, 2007 - 03:42 pm: |
i was wondering if anyone has done a big 3 on a grand cherokee with a 4.0... i want to know wich are the wires to change thanks for any help |
Silver Member Username: Jesse59672
OKLAHOMA
Post Number: 711 Registered: Feb-07
| Posted on Thursday, October 11, 2007 - 03:47 pm: |
you don't actually change any of them. leave the stock wiring there and just add on to them. |
Gold Member Username: Tremor1127
Fi
Post Number: 2330 Registered: Aug-06
| Posted on Thursday, October 11, 2007 - 11:50 pm: |
if you want to "change" your wires, more power to you. it hurts absolutely nothing by simply replacing them. i replace the wires in any install i have to do that in. just find all of the wires that go from your alternator and battery pretty much. those are the ones you want to "change" or "add to"... on your car there should be a wire from the alternator to a fusebox and a wire from the fusebox to the battery. i have deleted that completely and ran a new wire straight from the alternator to the battery. that wire should still be fused though. you should be able to find cheap fuse holders where you live. i can get nice 1/0 gauge fuse holders for 17ish bucks apiece...  |
Fi
Post Number: 2332 Registered: Aug-06
| Posted on Thursday, October 11, 2007 - 11:51 pm: |
i dont add to the wires because the factory wires sometimes look like hammered @$$... |
