Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Low RMS subs that sound good
Author Thread: Low RMS subs that sound good
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 430
as the title says, what are some low rms subs that will sounds good, i'm looking for 12's and i relaly sorta want 4 of em jus tbecause i've had about every other combination of sub, and i would be running 1000 rms, its probably far fetched but you guys know of any that sound good for 300 for four of em?
Username: Skies
Courtenay, British Colu...
Post Number: 814
Infinity Perfect
Username: Skibum12189
Cleveland
Post Number: 1875
go triple DIamond D312s (89 a piece, 400 rms each)
Username: Jakeyplaysbass
ASU
Post Number: 1986
(4) ED 13KV.3(black cone) or 13KV.2(silver cone) if you call them you can probably get them for 75-80 each which is a little more than u wanted to spend.
Username: Denim
Www.TeamSSAudio.com, MD
Post Number: 479
Assassin
Username: Boomtank
Rochester, NY
Post Number: 366
Diamond D3 12's would sound good
or Phenix Gold 12's
Username: Ruxpin20
DeTroiT, MIchiGan
Post Number: 94
i just bought one of these....
http://www.wakeside.com/page/w/PROD/image_dynamics_ID12D4?CAWELAID=81135291
from what i have heard, they sound good...
Username: Insearchofbass
Post Number: 6716
^^^^would be an excellent choice
Username: Glasswolf
Wisteria, Lane
Post Number: 12045
the key to good output with low power is finding an efficient sub.
look for something with a treated paper cone, and foam surround, and don't assume that a bigger magnet means it's better.
I've got a set of Cerwin Vega LE12D 12" subs made back in 1989, that are rated for 125w/coil (250WRMS per sub) and in a large ported box, using two of them in a Ford Festiva, @ 160 watts RMS each, I was hitting well into the 140dB range with a perfect C weighted curve.
The subs are terrific, clean, they were cheap, and don't need much power. It's mainly because they have an efficiency of something like 92dB compared to the typical sub these days rated around 82-88dB
Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Low RMS subs that sound good [ « Previous ] [ Next » ]
