Thread: Bigger amp? |
Bronze Member Username: Arwlacrosse182
Post Number: 22 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 10:32 pm: |
I have 2 12" Kicker CVR's and a Kicker ZX 250.2 amp. Would a larger amp make it louder? if so what would be a good upgrade? |
Post Number: 23 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 10:33 pm: |
they are 4 ohm 800 peak 400 rms |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 12971 Registered: Jul-05
| Posted on Wednesday, October 10, 2007 - 10:48 pm: |
yes a larger amp would make it louder..whats ur budget?? |
Post Number: 24 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 10:52 pm: |
$400 |
Gold Member Username: 420alldaylong
Post Number: 2697 Registered: Sep-06
| Posted on Thursday, October 11, 2007 - 12:28 am: |
http://www.millionbuy.com/powasa10001d.html http://www.millionbuy.com/roct5001bd.html |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1385 Registered: Mar-06
| Posted on Thursday, October 11, 2007 - 03:57 pm: |
I can give you a deal on a RD 1000.1. That would work well. Kevin |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4967 Registered: Dec-05
| Posted on Thursday, October 11, 2007 - 09:05 pm: |
the best choice |
Platinum Member Username: Glasswolf
Wisteria,
Lane
Post Number: 12041 Registered: Dec-03
| Posted on Friday, October 12, 2007 - 08:19 am: |
double the power from an amp will add +3dB. you need 10X the power (within the Xmax limits and power handling of the subs of course) to increase audible volume by 6-10dB (double the volume.) that being said, those CVRs should be getting 300 watts each to get them moving. also, consider a good ported enclosure if you want to increase output as well. |
