Thread: Speaker Wire |
Silver Member Username: Kaprese
Walstonburg,
NC
Post Number: 493 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 05:58 pm: |
Is Raptor speaker wire any good and also would it be a good idea to change my JL subs wiring from 14g to 12g ? Does it really matter |
Walstonburg,
NC
Post Number: 494 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 06:32 pm: |
Gold Member Username: Skibum12189
Cleveland
Post Number: 1866 Registered: Mar-06
| Posted on Wednesday, October 10, 2007 - 06:35 pm: |
what subs? |
Silver Member Username: Hurricanebr1an
Western Burbs of Chicago,
IL
Usa
Post Number: 151 Registered: Sep-07
| Posted on Wednesday, October 10, 2007 - 06:38 pm: |
from 14 to 12 wont make a difference..but if you're thinking about it go ahead and upgrade to 8 ga....and i cant comment on Raptor but speaker wire is pretty standard IMO. i've never heard anyone complain about it but remember you'll probly get what u pay for |
Gold Member Username: Southernrebel
Monroe,
Louisiana
2 DD3515s, 1...
Post Number: 5352 Registered: Mar-04
| Posted on Wednesday, October 10, 2007 - 06:43 pm: |
IIRC, Raptor wire is undersized. I think the 12ga is really like 14ga. (I may be thinking of XXXwire though) |
Monroe,
Louisiana
2 DD3515s, 1...
Post Number: 5353 Registered: Mar-04
| Posted on Wednesday, October 10, 2007 - 06:44 pm: |
Unless you are running outrageous amounts of power, 14ga is fine. |
Silver Member Username: Jtown
ATX,
Texas
| Posted on Wednesday, October 10, 2007 - 06:45 pm: |
yeah wires aren't standard, some aren't true to the ga stated..as canaan said, they are undersized usually. |
