Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Crx System?
Author Thread: Crx System?
Username: Bass_enjoyer
I recently bought a 91 honda crx si, and will be looking for a system to add in the next few months. I will take out all of the back panels to make more room. The biggest iraggi alternator I can find for it is 200 amps, which I plan on buying.
I want an spl-leaning SQL setup, or even SPL as long as it doesn't sound like *complete* crap. I have a 13w7 in my other car and would like something louder, if possible with the alt.
I was thinking a 18" Fi BTL, a Soundsplinter RL-P18 or RL-S15, or something else. I'm not too concerned with the amp as long as my electrical can handle it. Price isn't much of an issue; I can save up.
Any ideas? Thanks in advance for any replies.
Username: Cenus
Ohio
Post Number: 3626
whats your budget? if its over 2k i'd get a kx2500.1 and 2 dd9112, that would make a great sql setup.
I'd say around 2000 is a little high, but fair. I'd like to try a single large subwoofer, but will definitely have to look into that setup. Thanks
Username: Cenus
Ohio
Post Number: 3629
well maybe a zx1500.1 and a rl-p or maybe an eclipse ti that would be closer to 1k.
Username: Th3pwn3r
Post Number:...
Post Number: 5299
2 DD M3 Amps and 4 3512s in there.
Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Crx System? [ « Previous ] [ Next » ]
