Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Digital Designs DD M1 Amp
Author Thread: Digital Designs DD M1 Amp
Username: Frkkevin
¤ Resonant Engineering..., ¤ Fort Worth...
Email
Post Number: 3712
How much power does this amp actually put out? Heard its pretty under-rated
Username: Safe_cracker
Chicago, IL
US
Post Number: 3627
Series
M
Input Sensitivity
0.2V - 8V
Variable High Pass Filter
Subsonic Filter
10 Hz - 50 Hz at 24 dB/Oct
Variable Low Pass Filter
20 Hz - 200 Hz at 24dB/Oct
Clipping Display
LED
Tested Voltage
14.4V
Tested THD
1%
Model
M1a
M2
M3
Power at 4 ohm
300W x 1ch
390W x 1ch
600W x 1ch
Power at 2 ohm
Damping Factor
>250 @ 1 ohm
>250 @ 1 ohm
>450 @ 1 ohm
Power at 1 ohm
1200W x 1ch
1700W x 1ch
2400W x 1ch
Power at 4 ohm Mono
300W x 1ch
390W x 1ch
600W x 1ch
Power at 3 ohm Mono
Max Dynamic Power
2000W x 1ch
2500W x 1ch
4500W x 1ch
Efficiency thru Output
>75%
>75%
>85%
Dimensions - mm
300 L x 235 W x 53.4 H
350 L x 235 W x 53.4 H
540 L x 235 W x 53.4 H
Dimensions - inches
11.81 L x 9.25 W x 2.1 H
13.78 L x 9.25 W x 2.1 H
21.25 L x 9.25 W x 2.1 H
Signal to Noise
85 dB
85 dB
90 dB
Shipping Weight
12 lbs
16 lbs
24 lbs
Username: Frkkevin
Email
Post Number: 3715
should i buy it for my XXX :-)
Username: Zacdavis
Beloit, Wi
Post Number: 642
The M1 will do in the ballpark of 2000rms at 1/4 ohm for a few seconds, long enough for burping in competition.
At recommended impedance of 1 ohm it will hang with amps such as the KX1200.1, Massive 1500d, ect., pretty much any amp rated around 1200-1500rms. As for an exact rating, I dont know but I've done quite a bit of testing with them and I know what they they're comparable to.
The M1a, thats a different story. It isnt as powerful as the M1.
I was not impressed when we got them in stock, hmm, that may be misleading...The M1a IS rated correctly, the M1 was modestly rated, quite modestly actually. The M1a isnt overrated, but the M1 was so underrated when comparing the two it seemed like the M1a wasnt all that, wow, what screwed up post, sorry to be so confusing.
new M1a= good
old M1 = gooder
Username: Frkkevin
Email
Post Number: 3716
its the old M1
Chicago, IL
US
Post Number: 3628
Funny how they did that, there is a day/night difference from a Z1 and Z1a. You think they would have taken the same route with the M series. Polo..
Username: Frkkevin
Email
Post Number: 3717
its the old M1
Username: Frkkevin
Email
Post Number: 3718
its the old M1
Username: Frkkevin
Email
Post Number: 3719
its the old M1
Username: Budling
Cali
USofA
Post Number: 341
hey, is it the old M1?
Username: Th3pwn3r
Post Number:...
Post Number: 5298
Wow.Triple post FTW.6 minutes apart on each :-)
Username: Frkkevin
Email
Post Number: 3720
idk how that happened lmao. funny thing is i only posted it once then mozilla said page load error so i hit refresh once.. i figured at the most a double post.. triple post FTW lmao
Username: Frkkevin
Email
Post Number: 3722
i bought it anyways.. heres specs i found on ampguts
Class-D amplifier
600w x 1 13.5V @ 1 ohm (0.2% THD+N),
1300w x 1 - 14.4V @ 1 ohm (1.0 THD+N),
1700w x 1 - 14.4V @ 1 ohm (10% THD+N)
Username: Logan__tille
Team Revolution
Post Number: 8984
What did you pay for it?
Username: Frkkevin
Email
Post Number: 3723
$10
Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Digital Designs DD M1 Amp [ « Previous ] [ Next » ]
