Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Decisions, decisions.......
Author Thread: Decisions, decisions.......
Username: Kaerfpl
Spencerport, NY
Post Number: 623
Which do you guys think would perform best with 1200 Watts @1ohm?
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4676
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3194
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5469
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3804
Username: Nd4spd18
Northwest PA
Post Number: 3335
Orion and Powerbass are decent quality so I'd get one of those.
Username: Th3pwn3r
Post Number:...
Post Number: 5286
Those PCA-D series from Soundstream have been known to be very good amps as well.They're nothing like the rest of their garbage that they make these days.The only amps I wouldn't run would be the Hifonics and the Powerbass.I'd take the Orion and then the Soundstream and forget the other two.
Username: 420alldaylong
Post Number: 2688
Out of the 4 you listed above I would take the Orion HCCA-D2400 or the Soundstream PCA1500D.
Powerbass ASA amps do around %80 of rated power so if your looking at Powerbass ASA.
Take a look at the ASA2000.1D
http://www.millionbuy.com/powasa20001d.html
MillionBuy spec are wrong for the ASA2000.1D
Powerbass ASA2000.1D
500x1 @ 4ohm
1000x1 @ 2ohm
2000x1 @ 1ohm
Username: Th3pwn3r
Post Number:...
Post Number: 5308
Yea...the Picasso series is good sh1t and no joke.
Post Number: 2693
Sorry to steal the thread
Rob
What #s are you hitting with them 4 DD3515s?
Username: Kaerfpl
Spencerport, NY
Post Number: 625
Ok, so if my calculations are right, then that ASA would be putting out 1600 Watts at 1ohm? If so then that would be 800 Watts to each sub. RMS is 600 Watts so I highly doubt an extra 200 Watts on my SE's would do any damage. What size wiring should I use with that amp? 1/0 gauge?
Also, I was always curious if that Orion HCCA2400 put out more than what it's rated at 1ohm?
Username: Kaerfpl
Spencerport, NY
Post Number: 626
I just found this US Amp for around the same price:
http://www.millionbuy.com/usaxt2000d.html
Between the HCCA2400, ASA2000, and this US Amp, which do you think would perform better?
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4968
in output, powerbass ASA, the us amp is an entry model so it won't do 2000w rms, maybe something like800-1000w rms.
If the price is right, get the ASA, lil extra power won't hurt, plus you could benchtest it for us
Username: Kaerfpl
Spencerport, NY
Post Number: 628
lol, im really thinkin of getting the ASA when I get my next paycheck.
Can I get an amp bench tested at any local shop? It doesn't cost anything does it?
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Decisions, decisions....... [ « Previous ] [ Next » ]
