Thread: What cud be wrong |
Bronze Member Username: Maddoggvup
Omaha,
NE
Post Number: 14 Registered: Sep-07
| Posted on Tuesday, October 09, 2007 - 09:50 pm: |
put in new HU same as last one and now my amp keeps going on protect what do u think it cud be |
Platinum Member Username: Wingmanalive
A pic is worth
1000 posts!!
Post Number: 10496 Registered: Jun-06
| Posted on Tuesday, October 09, 2007 - 10:15 pm: |
Bad wiring, bad ground, short somewhere. Many possibilities. |
Omaha,
NE
Post Number: 15 Registered: Sep-07
| Posted on Tuesday, October 09, 2007 - 11:35 pm: |
same wiring unplug old. plugin new one.i dont think it wud be HU wiring. what else cud it be |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 388 Registered: Jul-07
| Posted on Wednesday, October 10, 2007 - 12:06 am: |
ia your ohm load matched for the amp and subs???? |
Silver Member Username: Jtown
ATX,
Texas
Post Number: 477 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 12:53 am: |
it's prob the remote wire grounding out or just a poor ground for the amp. is there paint where you grounded the amp or bare metal? |
Omaha,
NE
Post Number: 16 Registered: Sep-07
| Posted on Wednesday, October 10, 2007 - 01:41 am: |
omh is right. it mite be the remote. there waz paint sanded it off now bare metal |
Omaha,
NE
Post Number: 17 Registered: Sep-07
| Posted on Wednesday, October 10, 2007 - 02:49 am: |
it duz it win i tern it up never did it befor |
Gold Member Username: The_image_dynamic
San Diego
Post Number: 2920 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 03:19 am: |
Your spelling could be slightly wrong. Ghetto grammar is rarely cute unless you are in fact a ghetto thug who can shoot everyone who determines that you are ignorant. But you're probably not, so stay in school. Translation: Youz spelling is wack yo, stay in skool dawg to keep it realz and shìt. Wurd. |
Silver Member Username: Greeney1888
Clover Grove Im rich btch...
Post Number: 406 Registered: Feb-06
| Posted on Wednesday, October 10, 2007 - 03:35 am: |
haha brad. ghettos in omaha? ...naw |
ATX,
Texas
Post Number: 481 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 10:39 am: |
clipping? |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5259 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 10:53 am: |
It could be that you lack the intelligence to properly set up your system.You should probably pay a professional to install your system because you aren't showing many signs of intelligence based upon your posts.Check the wiring on your subwoofer.Disconnect the subwoofer from your amplifier and if it's still in protect then your amp is fucked. |
ATX,
Texas
Post Number: 482 Registered: Mar-07
| Posted on Wednesday, October 10, 2007 - 10:57 am: |
that was a lil uncalled for... |
Post Number:...
Post Number: 5265 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 11:11 am: |
"that was a lil uncalled for..." Not really.If he wants help he should probably try to post so it's legible.Feed your amplifier a signal through an ipod using a Y cable from a headphone jack to RCAs.Feed that into the amplifier and see if your amplifier is still in protect,most likely it will be.Does your amplifier go into protect as soon as you turn it on or is it going into protect after playing for a bit?You may be going into the thermal protection for whatever reason. |
