Thread: New stuff |
New member Username: Jshak07
Post Number: 1 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 06:29 pm: |
I need some advice. I have 2 cerwin vega stroker 122s (12 inch) and they are 4 ohm, 2000w rms 4000w max per sub. I have a 2 channel 1200W kicker amp and a 2 channel 2400W lanzar amp. What is the best way to hook these and should i buy a capacitor or battery?} |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4965 Registered: Dec-05
| Posted on Tuesday, October 09, 2007 - 09:00 pm: |
first of all, sell your lanzar amp, it won't push those subs, second thing is to use your kicker amp for components. You need 4000w rms at 1 ohm, that's expensive, but you can get good bump with a rockford t2000bd |
Post Number: 2 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 10:06 pm: |
i got a buddy that got the same lanzar amp on 2 15" L7s and it bumps harder than anything i ever heard so i trust the lanzar brand but how do i connect both amps and should i get a capacitor or what? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3330 Registered: Jul-06
| Posted on Tuesday, October 09, 2007 - 10:38 pm: |
Ya need a lot bigger amp. That 2400 is max watts so you won't even get half of that. And lanzar blows big time except for the opti series. |
Post Number: 4 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 11:56 pm: |
ok so sell the lanzar but wut about the kicker? can it be wired with another amp to increase watts or should it be sold and replaced as well? |
Platinum Member Username: Rovin
4 10 Pioneer...
Post Number: 12327 Registered: Jul-05
| Posted on Wednesday, October 10, 2007 - 12:16 am: |
sell both & buy the correct amp..... |
Post Number: 6 Registered: Oct-07
| Posted on Wednesday, October 10, 2007 - 11:41 am: |
the kicker amp is good stuff and jus wat do u suggest the correct would be |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5277 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 01:03 pm: |
If you want full potential out of your subs find yourself a 4,000 watt RMS amp.Look for a memphis 4kw or possibly a RF 4K rms amp,you could also look into an amp from the XX line from Hifonics. |
4 10 Pioneer...
Post Number: 12334 Registered: Jul-05
| Posted on Wednesday, October 10, 2007 - 03:07 pm: |
yep thats what i meant by correct u get a good amp that powers at least the wrms the subs require ..... |
Post Number:...
Post Number: 5288 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 03:32 pm: |
Don't forget to beef up your charging system when thinking about running that kind of power. |
Gold Member Username: 420alldaylong
Post Number: 2689 Registered: Sep-06
| Posted on Wednesday, October 10, 2007 - 06:57 pm: |
I have never seen a Kicker 1200watt 2 channel amp. |
Post Number: 2690 Registered: Sep-06
| Posted on Wednesday, October 10, 2007 - 07:02 pm: |
Oh yeah upgrade your charging system like Rob said. Your system is only as good as its weakest link. |
Post Number: 8 Registered: Oct-07
| Posted on Wednesday, October 10, 2007 - 09:34 pm: |
wat do i need a capacitor or a battery? someone suggested that i get a 5000.1 amp? |
Bronze Member Username: Jshak07
Post Number: 11 Registered: Oct-07
| Posted on Wednesday, October 10, 2007 - 09:51 pm: |
it is a real amp joey desalvo KICKER ZX450.2 450 WATT RMS AND 1200 WATT MAX OUTPUT 2 CHANNEL BRIDGEABLE CAR AMPLIFIER
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 6424 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 10:21 pm: |
that amp wont even get close to properly powering your subs....your gonna need about 4krms @ 1 ohm....which will be costly, very costly....then you'll need to beef up the electrical (alt, batts, big 3) which will make the price of the proper amp you need seem cheap.....have fun bud hope you got a couple grand to throw around |
Post Number: 2695 Registered: Sep-06
| Posted on Thursday, October 11, 2007 - 12:22 am: |
That Kicker ZX450.2 does around 500-550RMS at 4ohm mono bridged. No where near 1200 watts. |
Post Number: 12 Registered: Oct-07
| Posted on Thursday, October 11, 2007 - 04:37 pm: |
That isnt the amp I am using I realize that it has not near enough power for what I need but he didnt think it was a real amp. It maxes out at 1200 watts. |
Northwest PA
Post Number: 3341 Registered: Jul-06
| Posted on Thursday, October 11, 2007 - 05:12 pm: |
So, like Joey said, it is a 500 watt amp. Max watts means nothing FYI |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 2030 Registered: Jun-06
| Posted on Thursday, October 11, 2007 - 05:24 pm: |
Post Number: 2698 Registered: Sep-06
| Posted on Thursday, October 11, 2007 - 05:35 pm: |
I don't remember seeing peak power ratings on a Kicker amp. Where did you see that at? |
Silver Member Username: •cam•
Post Number: 830 Registered: Nov-06
| Posted on Thursday, October 11, 2007 - 06:40 pm: |
eBay probably. |
Post Number: 14 Registered: Oct-07
| Posted on Friday, October 12, 2007 - 08:14 am: |
MTX THUNDER 81001 1 MONO.. 2 of these on the vegas? |
