Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Jl w6 ?????
Author Thread: Jl w6 ?????
Username: Mike_16
Burlington, Wisconsin
Us
Post Number: 621
are 2 of them brand new worth $50?? and wil they get decently loud and how much power can they actually handle?
Username: Skibum12189
Cleveland
Post Number: 1856
.....are you kidding me?
if youre not kidding, then yes, its a great deal, won't be really really loud, but they should handle about 500 rms a piece or more if theyre the v2s
Username: Ctmike
Ct.
Post Number: 5294
$50 for a pair!?? can you get me a pair to?
but you're kidding, right?
Username: Blainew
Post Number: 2689
he meant 500 i bet
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 12954
I will give you $100 for them right now :-)
Username: Mike_16
Us
Post Number: 622
oh my bad yes i meant 500. sry bout that guys. wel yea my buddy has 4 of them in his 200 roush mustang and it is to much he said for his car cuz he has it set up for drag racin and idk its pushin 625 h/p and he said he just dont need that much power in that car so he wanted to sel 2 of em. wel yea so would 2 of them handle a kicker kx1200.1 amp?
Username: Joebruce
15 AQ HD3
Post Number: 1497
Well since hes your buddy Id try and talk him down to like $400 or lower. As for the Kicker amp thats kinda pushin it cuz the W6s are only 400wrms but if you set the gain right you should be ok. If you dont already have that amp then Id look for one that does 1000wrms @ 1ohm.
Home > Message Board > Car Audio > Subwoofers > Archive through October 12, 2007 > Jl w6 ????? [ « Previous ] [ Next » ]
