Thread: Need Help |
New member Username: Joebud91
Post Number: 1 Registered: Oct-07
| Posted on Monday, October 08, 2007 - 09:33 pm: |
I have 4 12" subs. The RMS is 150 and the peak is 800 on each. Any Suggestions as to what amp i need for them all together with a good sound that is not too expensive. |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 2010 Registered: Jun-06
| Posted on Monday, October 08, 2007 - 10:29 pm: |
What subs do you have? |
Post Number: 3 Registered: Oct-07
| Posted on Monday, October 08, 2007 - 10:34 pm: |
pioneer 12" |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1375 Registered: Mar-06
| Posted on Tuesday, October 09, 2007 - 01:26 am: |
Are they 2 or 4 ohm? Dual or single voice coil? Kevin |
Post Number: 7 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 07:24 am: |
4 ohm single |
Columbus,
GA
Post Number: 1376 Registered: Mar-06
| Posted on Tuesday, October 09, 2007 - 01:30 pm: |
I have a RD 550.1 that would work well with them. Amp does around 610 rms @ 1 ohm. Shoot me an email for price. Kevin lowhz01@yahoo.com |
New member Username: Malkusth4
Penuelas,
Puerto rico
| Posted on Tuesday, October 09, 2007 - 08:35 pm: |
Quiero liberarme de los altos pagos a dishnetwork y compre una caja demoduladora pansat 3500SD,pero tengo problemas para programarla,sigo las instrucciones,pero no logro ponerla a funcional,alguien que pueda darme una manita en esta situacion.Gracia a todos los que lean esta nota, solo para -hispanos- |
Penuelas,
Puerto rico
Post Number: 2 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 08:44 pm: |
I have a pansat 3500Sd,but I need help to program. thanks |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4962 Registered: Dec-05
| Posted on Tuesday, October 09, 2007 - 08:45 pm: |
Bueno louis tu estas en la seccion equivocada, chequea una seccion de DVD y sistemas televisivos |
