Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > 1995 toyota 4runner limited, help wit...
Author Thread: 1995 toyota 4runner limited, help with speaker placement
Username: Imjustme87
Tullahom, Tn
United States
Post Number: 11
Hey guys, i just purchased a 1995 toyota 4runner limited. Well, it's got 4" speakers in the dash, 5.25's in the rear doors, and 6.5" in the far back, i want a frontstage, not a rear. I hate rear sound, what's the best way to get a good front-stage? i dont want to spend the money on kick-panel speakers, but do i have any other options?
Username: Adddisorder
Palm Beach, Florida
Post Number: 5205
make a MDF ring to cover the existing speaker hole and to mount a 6.5 speaker in place. then run an amp for them and unplug your other speakers. but decent stuff and get a little sq sub and it will sound nice.
Tullahom, Tn
United States
Post Number: 12
there isn't another speaker hole, there's none in the doors, and just some vents where some go in the dash itself, would rather not cut a hole in the door if possible, are kick panels my only option?
Palm Beach, Florida
Post Number: 5228
oooh ok, or you can put in 4" speakers in your dash. otherwise cut a hole in your door or build some kickpods.
Username: Glasswolf
Wisteria, Lane
Post Number: 12040
use kick pods
Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > 1995 toyota 4runner limited, help wit... [ « Previous ] [ Next » ]
