Thread: Headunit suggestions |
Gold Member Username: Insearchofbass
Post Number: 6685 Registered: Jun-04
| Posted on Monday, October 08, 2007 - 05:50 pm: |
so far im looking at the kenwood excellon series any suggestions.....three sets of preouts and some functions |
Post Number: 6686 Registered: Jun-04
| Posted on Monday, October 08, 2007 - 05:56 pm: |
or a Clarion DXZ575USB CD/MP3/WMA Receiver with Remote and USB Input Power Output: Peak: 53 watts x 4 channels RMS: 19 watts x 4 channels Built-in CEA-2006 compliant amplifier Fold-down, detachable face with 2-line display Digital Z-Enhancer EQ with three preset tone settings and 2-band parametric equalizer Sound Restorer for use with compressed music files Multi Bit digital-to-analog converter High- and low-pass filters Subwoofer level control Compatible with Clarion Bluetooth adapter Compatible with Clarion iPod adapter Satellite radio-ready (tuner, antenna, and XM or SIRIUS service subscription required) Auxiliary input CD changer controls Three sets of 5.7-volt preamp outputs Seek tuning Clock CD Frequency Response: 5 Hz - 20,000 Hz FM sensitivity: 9 dBf In-Dash Receiver Specifications: Receiver Size Single DIN Faceplate Security Detachable Remote Control Yes Peak Power Output 53 watts x 4 channels RMS Power Output 19 watts x 4 channels Preamp RCA Outputs 3 Pairs (Front, Rear, and Subwoofer) Sub Preamp RCA Output Yes Preamp Voltage 5.7 volts Built-In Equalizer 2-Band Parametric EQ -- Digital Z-Enhancer with 3 preset curves |
Post Number: 6687 Registered: Jun-04
| Posted on Monday, October 08, 2007 - 07:30 pm: |
bump |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3324 Registered: Jul-06
| Posted on Monday, October 08, 2007 - 08:34 pm: |
JVC KD-AR880 Front panel USB input and hi voltage preamp outputs. I have one and it's the best HU I've had so far. |
Silver Member Username: Zero43
Fort gordon,
Georgia
Post Number: 238 Registered: May-05
| Posted on Tuesday, October 09, 2007 - 01:24 am: |
how much did you see the clarion for I had a kenwood excelon x979 before I loved it and the guy I sold it to loves it as well unfortunately kenwood quit making them like that |
Post Number: 6692 Registered: Jun-04
| Posted on Tuesday, October 09, 2007 - 09:56 am: |
im skipping the kenwood excellon's I think and cant find the jvc you mentioned |
Northwest PA
Post Number: 3328 Registered: Jul-06
| Posted on Tuesday, October 09, 2007 - 06:38 pm: |
How did you not find it? I just searched google and ebay http://mobile.jvc.com/Aproduct.jsp?modelId=MODL027896&pathId=142&page=1 http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=JVC+KD-AR8 80&category0= |
Post Number: 6707 Registered: Jun-04
| Posted on Wednesday, October 10, 2007 - 05:16 pm: |
ed on ebay the other day but didnt do a specific search .....I must have overlooked it when I scanned through...thanks |
