Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9022 Brake Override?
Author Thread: Jensen VM9022 Brake Override?
Username: Ekgaudio
I just got the VM9022 model and I have not found a brake override code for it. Does anybody know it yet? I have tried the 9412 and the old 9021, and they don't work.
Relevant Product Info
Username: Fromrum
Good News!!
Press setup on remote control.
After enterning the setup screen:
1) Select the "Language" tab
2) Once in the language selection menu, press: 543210.
3) A menu "secret" screen will appear, select the "Hammer and Screwdriver" button
4) Select "Brake Override"
5) Select "On"
6) Press "Setup" on the remote again to exit screen.
WOALA!!!!
Username: Nicolajpj
Falster
Denmark
Thx a lot - It works perfectly on my VM9022!!!! :D
Username: Yiannos77
I need help for bluetooth. When i switch to bluetooth function the microphone symbol is marked with a red X and it cannot be paired with my phone. Is this normal? How can i connect my phone. Yes it supports HFP and HSP profiles.
Post:
Username: Need to Register?
Password: Forgot Password?
Action:
Home > Message Board > Car Audio > Multimedia Systems > Jensen VM9022 Brake Override? [ « Previous ] [ Next » ]
