Thread: Recommend amp for JL 12w7 |
Bronze Member Username: Matt_uk
Post Number: 15 Registered: May-07
| Posted on Sunday, October 07, 2007 - 08:58 am: |
I have recently bought a JL 12w7 in a letterbox ported box. To get the best out of my w7 i would be willing to fork out the expences of a JL1000/1 but just wondering if anybody had any other suggestions on any other amps that would run the sub to a similar standard. Thanks |
Bronze Member Username: Djb0501
Post Number: 43 Registered: Jul-07
| Posted on Sunday, October 07, 2007 - 07:38 pm: |
1000/1 is to the 12w7 as thunder is to lightning. |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1370 Registered: Mar-06
| Posted on Sunday, October 07, 2007 - 09:54 pm: |
Well, if you plan on getting 1 JL W7, you can run the sub at 1.5 ohm on a Sundown Audio SAZ-1500D and be very happy. Email me if interested. Kevin lowhz01@yahoo.com |
Silver Member Username: Cblaze
Tn
Us
Post Number: 151 Registered: Sep-07
| Posted on Sunday, October 07, 2007 - 10:32 pm: |
jl 1000/1 |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 428 Registered: Jul-05
| Posted on Monday, October 08, 2007 - 12:55 pm: |
how do you run the w7 at 1.5 ohms, for like the 10th time in 2 weeks, arn't they ALL SVC 3 ohm subwoofers , so he'd have to have two of em to get it down to 1.5 |
Gold Member Username: Van_man
Boston South,
MA
Post Number: 2932 Registered: Mar-06
| Posted on Monday, October 08, 2007 - 01:40 pm: |
almost all. The 13.5 W7 is a dvc 1.5. So again, it would be more practicle to tun a 13 at 3 ohms. But all the other W7's are svc 3 ohms. So you need an amp that will push 750wrms plus,at 3 ohms. Bridging a 2 channel may not work, cause most are only 4 ohm stable when bridged. If you can find a mono amp that does 850-1000wrms at 2 ohms, then it will put out about700-850 at 3 ohms, in thereoy and if its a quality amp. Simply solution 1000/1 |
Columbus,
GA
Post Number: 1372 Registered: Mar-06
| Posted on Monday, October 08, 2007 - 03:17 pm: |
My bad, I thought they were dual 3 ohm subs. Oops. Kevin |
New member Username: H3tor
Post Number: 1 Registered: Oct-07
| Posted on Tuesday, October 09, 2007 - 04:08 am: |
the 1000/1 or 500/1 will be the best choice, if you are considering another amplifier for your 12w7 you gone damage that suspension. |
Post Number: 16 Registered: May-07
| Posted on Wednesday, October 10, 2007 - 08:01 am: |
would it still hit hard and sound quality be good even with a jl 500/1? |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5274 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 12:46 pm: |
It would still have the same sound quality on a 500/1 unless you think that a louder sub sounds better. |
Platinum Member Username: Rovin
4 10 Pioneer...
Post Number: 12335 Registered: Jul-05
| Posted on Wednesday, October 10, 2007 - 03:10 pm: |
the phoenix gold xenen 1200.1 was rated 1200wrms from 1-4ohms so that maybe a cheaper choice IF u can still find that amp ..... |
4 10 Pioneer...
Post Number: 12336 Registered: Jul-05
| Posted on Wednesday, October 10, 2007 - 03:11 pm: |
^^^scrap that idea since i was thinking its a 13w7 u had ...... |
Post Number:...
Post Number: 5293 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 04:02 pm: |
Way to noob it Rovin  |
