Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Need mono amp for 3 kicker s12d have ...
Author Thread: Need mono amp for 3 kicker s12d have bout a 200-250 dollor budget
Username: Chubby_boy
T.A.Z.
duz any1 knw da best mono amp amp to run 3 kicker s12dz on i have bout 200-250 i wana spend
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4959
post subs specs, voice coil config please
T.A.Z.
diz iz wut i found on another post
Round 12" cast aluminum, heavy duty frame
60 oz. magnet weight
168 oz. magnet structure weight (10 lbs+)
Talc filled Copolymer cone
Santoprene Surround glued and stitched to cone body
2" , 4 Ohm heavy duty voice coil on space age Kapton former
Sleeved leads to prevent shorting
Perimeter spider vents for additional cooling and smoother performance
Extended pole for exceptional voice coil cooling
Heavy duty lead connectors (will accept 4 gauge wire)
Designed for small sealed enclosure - .88 cu.ft. recommended
Technical Specifications
600 watt maximum power handling capability
24-100 Hz Frequency Response
Fs =21.79 Hz (Free air resonance frequency of driver)
Qms=8.647 (Mechanical damping)
Qes=0.3870 (Electrical damping)
Qts=0.3704 (Total damping of woofer at Fs)
Vas=131.11 liters (Volume of air having the same acoustic compliance as the enclosure)
Cms=0.3261E-03 M/N (Suspension compliance)
Re=3.47 ohms (DC voice coil resistance)
BL=14.170 Newtons/Amp (Force factor)
Sd=0.053502 sq. mtrs (effective surface area of driver cone)
Mms=0.163589 Kilograms (Moving mass)
Hvc=1.170" (Voice coil winding height)
Hag=.500" (Air gap height)
Xmax=0.335 (Linear excursion, one direction, equals voice coil overhang)
Xlin p-p=.670 (Total linear excursion, peak to peak)
Ref Efficiency=0.3368%
Predicted Output=87.474 Db/1W/1M
Username: Naledge503
Http://com4.runboard.c...
Post Number: 2028
They are single 4 ohm. I can only find the max rating for them, which is 600 max, so basically cut that in half.
You are gonna want an amp that does 1000 watts rms at 1 ohm. Your final impedance will be 1.33
Check out this amp...Its a good deal.
http://www.caraudio.com/forum/showthread.php?t=263590
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4969
for 250$ grab a power acoustik a 1800DB, that way you get the power you need for the budget
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Need mono amp for 3 kicker s12d have ... [ « Previous ] [ Next » ]
