Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Setting gain on amp
Author Thread: Setting gain on amp
Username: Talon01
12 audioque 2.5 144.8 ..., Pa
Usa
Post Number: 186
i know a dmm but the question i have is , i have a xenon 1200.1 rms is from 1 to 4ohms power so do i set it at 4 ohms at 69.3v or 2 ohm at 49v
its gonna be unning at 2 ohms and is 53 hz a good feq. to set it at caus thats the tone i burp it at
Username: Nd4spd18
Northwest PA
Post Number: 3294
It doesn't matter what freq. you use. You use the impedance (ohms) that the amp with be running at to calculate the voltage for setting the gain.
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Setting gain on amp [ « Previous ] [ Next » ]
