Thread: RF X7 protection mode |
Silver Member Username: Xstokes88
San Antonio,
Texas
United states
Post Number: 126 Registered: Nov-05
| Posted on Friday, October 05, 2007 - 10:30 pm: |
i have 2 2ohm dvc 12" L7s.. i also have a rockford fosgate x7 type rf amp n it keeps going into protection mode if i turn the gain up at all or if i turn the volume up a quarter of the way.. anybody kno how i can fix this? any help would be appreciated..thnx |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3296 Registered: Jul-06
| Posted on Saturday, October 06, 2007 - 12:10 am: |
how are the subs wired, and whats the min. ohm load for the amp? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4954 Registered: Dec-05
| Posted on Saturday, October 06, 2007 - 09:57 am: |
the amp is 2 ohm stable, maybe he wired it at 0.5 ohms:S |
Bronze Member Username: Thunderb
Post Number: 70 Registered: Sep-07
| Posted on Saturday, October 06, 2007 - 02:57 pm: |
"the amp is 2 ohm stable, maybe he wired it at 0.5 ohms:S" That would explain the protection light. To tell the truth I cant believe that amp will even turn on @ 0.5 ohms. The only way to run this amp would be to parallel the 2 subs @ 1 ohm then to run them in series. Or he can run them in series to get 4 ohms then parallel to 2 ohms. |
Post Number: 4958 Registered: Dec-05
| Posted on Saturday, October 06, 2007 - 03:43 pm: |
X, go to www.the12volt.com Hit the link woofer wiring and post specs, then you'll see a full wiring diagram. |
San Antonio,
Texas
United states
Post Number: 127 Registered: Nov-05
| Posted on Saturday, October 06, 2007 - 04:44 pm: |
thnx guys i appreciate it..i had them wired to .5ohms |
San Antonio,
Texas
United states
Post Number: 128 Registered: Nov-05
| Posted on Saturday, October 06, 2007 - 05:31 pm: |
"he can run them in series to get 4 ohms then parallel to 2 ohms." how do u do this? |
