Thread: Does anyone have an opinion on this amp? |
Bronze Member Username: Teomcdohl
Wantagh,
Ny
Post Number: 16 Registered: Jul-04
| Posted on Thursday, October 04, 2007 - 10:10 pm: |
JL a6450 - 6 channel with balanced inputs. Looking to buy one for my TSX. Any opinions? |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5211 Registered: Jul-06
| Posted on Thursday, October 04, 2007 - 10:45 pm: |
Anything from JL Audio is pretty much a quality product.Their amps are very efficient and they put out pretty good sound quality too.I'm not familiar with that exact model that you're talking about but any JL product usually performs pretty well but you pay a hefty fine(Hefty Fine was the name of a BloodHound Gang CD ) for it too. |
Bronze Member Username: Thunderb
Post Number: 68 Registered: Sep-07
| Posted on Friday, October 05, 2007 - 04:22 pm: |
I agree with Rob. JL Audio has always made good amplifiers and subwoofers. I think the price you pay for their name to be on that amplifier or subwoofer is way to steep though. You can get amplifiers made just as well or better for less. |
Bronze Member Username: Dj_007
Carlisle,
KY
US
Post Number: 79 Registered: Dec-06
| Posted on Sunday, October 07, 2007 - 03:06 am: |
JL audio is over rated over priced.. and thier support is horriable.. i have a buddy with one of those amps and it isnt quite what i woudl expect for what it costs.. i ahve personally owned a 450/4 and a 1000/1 and after a year of being run hard but with 1/0 power and grounds, big 3, and 2 extra batteries so i know where where getting clean signal i started getting horriable amplifier noise.. the regulated power supplies get hot and dont last long.. buy something else if u want something to keep for years to come. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3298 Registered: Jul-06
| Posted on Sunday, October 07, 2007 - 04:37 pm: |
JL amps are not over rated and the are reliable, well built. They ARE overpriced though. |
Carlisle,
KY
US
Post Number: 83 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 10:55 am: |
ok take an A 1800 for example.. says at 2 ohm it does 1000 watts.. no it doesnt.. it may do 800.. but every one i have ever installed or used was the most un impressive 800 watts iv seen... |
Northwest PA
Post Number: 3336 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 03:17 pm: |
JL Amps are known to do their rated power. |
Post Number:...
Post Number: 5285 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 03:26 pm: |
"JL Amps are known to do their rated power." Yep.Also,they do their rated power at just about whatever ohm load you give them. |
Gold Member Username: Carguy
Post Number: 6532 Registered: Nov-04
| Posted on Wednesday, October 10, 2007 - 03:29 pm: |
Derek, maybe you've mistaken JL with Pyramid/Sony? |
Post Number:...
Post Number: 5287 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 03:30 pm: |
Hahaha.I knew you'd come Isaac  |
Post Number: 6533 Registered: Nov-04
| Posted on Wednesday, October 10, 2007 - 03:37 pm: |
Yeah, so you got me! Maybe next time I won't come or be busy at the subs forum. |
Post Number:...
Post Number: 5291 Registered: Jul-06
| Posted on Wednesday, October 10, 2007 - 03:56 pm: |
I like bounce all around and hit up every section that I can  |
Carlisle,
KY
US
Post Number: 84 Registered: Dec-06
| Posted on Wednesday, October 10, 2007 - 09:39 pm: |
ok i have worked selling and installing JL audio equipment.. and i know what its like.. im not impressed at all especially for what it costs.. also as for about them doing the same power at any ohm load?? only the / "slash" series do taht.. they do the same power from 1.5 to 3 ohm and that is accomplished with an extremely power hungry regulated power supply that gets really hot.. because they are designed for the W7.. the A and E series amplifiers especially mono amps are 2 ohm stable. and absolutely will not run at any ohm loads lower that than.. i know from experience.. that is very un impressive to me since the MTX TC series amps are 2 ohm stable and will run daily at 1 ohm.. and cost half as much.. |
Northwest PA
Post Number: 3339 Registered: Jul-06
| Posted on Thursday, October 11, 2007 - 12:18 am: |
But MTX amps suck |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4970 Registered: Dec-05
| Posted on Thursday, October 11, 2007 - 09:35 pm: |
MTX doesn't suck that way M.S, they're just very expensive for what they do, for example a 1502D is good, it was a popular amp back then, but not the greatest thing. |
Carlisle,
KY
US
Post Number: 85 Registered: Dec-06
| Posted on Thursday, October 11, 2007 - 10:20 pm: |
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3975 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5586 and the MTX can be abused way more.. aka i can be ran at 1 ohm daily.. i know people that do it.. |
Silver Member Username: Cblaze
Tn
Us
Post Number: 173 Registered: Sep-07
| Posted on Friday, October 12, 2007 - 12:11 am: |
mtx are good amps i have the mtx ta4501 but i never tried running it at 1 0hm.jl is a TOP line amp but they are not worth it cuz just about every top line thang they charge mmore than its really worth,just because they are stengy beaches |
