Thread: Mixing sub sizes |
Bronze Member Username: Blackdouglas76
Post Number: 12 Registered: Oct-07
| Posted on Thursday, October 04, 2007 - 01:36 pm: |
does anyone see anything wrong with mixing 2 8" with 2 10" as long it is the exact same model, ohms, and year? This should keep my sound balanced and allow me the space I need. JIM |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5204 Registered: Jul-06
| Posted on Thursday, October 04, 2007 - 05:33 pm: |
I think it would be a better idea to run all 8s if you're thinking about that 8'' subs do have the ability to get loud if installed properly in case you were thinking they wouldn't get loud. |
Silver Member Username: Warlok
Orlando,
FL
Post Number: 384 Registered: Dec-05
| Posted on Friday, October 05, 2007 - 11:39 pm: |
Ya, not a good ideal. YOu can do it, but they will emit diff soudns, and maybe have slightly diff reaction times (or more or less accurate to each other). It wont hurt anything. Just know that the performance will NOT be linear between them. Lots of factors will make it almost impossible to be matched accurately. |
Gold Member Username: Alteraudiousa
Concord
Post Number: 1593 Registered: Jan-06
| Posted on Saturday, October 06, 2007 - 05:09 pm: |
you will need to crossover properly. |
