Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Confused on a wire harness
Author Thread: Confused on a wire harness
Username: Dubmc23
Rapid City, SD
Post Number: 9
ok heres the deal im installing a pioneer deck in an 06 monte carlo and i cant figure out y the deck wont turn on but then i see that there is a posative and negative for the ignition and 12 volt where the heck do i connect the negatives to???? and is that even my problem???
Username: Glasswolf
Wisteria, Lane
Post Number: 12033
get wiring harness adapters for an 06 GM, and wire those to the radio's harness.
then just plug the radio in without cutting any wires.
ground to a good metal ground point behind the dash.
Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Confused on a wire harness [ « Previous ] [ Next » ]
