Thread: Alt |
Silver Member Username: Homegrowncam
Funky Town,
TX
United States
Post Number: 424 Registered: Jan-05
| Posted on Sunday, September 30, 2007 - 06:30 pm: |
My stock alt is only about 80amps and I had some problems with my charging system when I was running a sx900.4. Now I have plans to get a new alt an EA quoted me $365 for a 180amp and then on ebay I found an Iraggi but the Iraggi is 200amp/90idle. My question is Is 90 at idle alrgiht? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3258 Registered: Jul-06
| Posted on Monday, October 01, 2007 - 01:08 am: |
It is ok, you just can't play the system full blast with it at idle. Most HO alts only do around 100 amps at idle, its hard to get more than that. |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5145 Registered: Jul-06
| Posted on Monday, October 01, 2007 - 11:25 am: |
That's why I raised my idle Stopping isn't that easy though lol.My brakes get destroyed pretty quick but it's worth it.It's cheaper to replace brakes than it is my subs or amps  |
Northwest PA
Post Number: 3270 Registered: Jul-06
| Posted on Monday, October 01, 2007 - 07:10 pm: |
Thats not good for your engine and transmission either....... I would never change the idle out of spec on any of my vehicles. My alternator does 100 amps at idle at it supports my 3kw system just fine, I just dont blast it at stoplights and such. |
Funky Town,
TX
United States
Post Number: 425 Registered: Jan-05
| Posted on Monday, October 01, 2007 - 09:49 pm: |
So would get a 2nd batt help any? |
Northwest PA
Post Number: 3277 Registered: Jul-06
| Posted on Monday, October 01, 2007 - 10:23 pm: |
No, batteries are not a substitute for an HO alt. |
Funky Town,
TX
United States
Post Number: 426 Registered: Jan-05
| Posted on Monday, October 01, 2007 - 10:46 pm: |
no i am talking about in addition to the alt. |
Funky Town,
TX
United States
Post Number: 429 Registered: Jan-05
| Posted on Wednesday, October 03, 2007 - 06:28 pm: |
bump |
Northwest PA
Post Number: 3283 Registered: Jul-06
| Posted on Wednesday, October 03, 2007 - 11:20 pm: |
No you just need a good alt and 1 good battery. |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 5153 Registered: Jan-06
| Posted on Wednesday, October 03, 2007 - 11:52 pm: |
a second batt in addition to the HO will help at idle, because when driving the alt will recharge the batteries. |
