Thread: Audibahn a1300hct |
Silver Member Username: Cblaze
Tn
Us
Post Number: 108 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 06:03 pm: |
how good are there amps,not as cheap as there subs about 750 msrp on that one thats rated at 1200 rms at 1 0hm,and the part i like is they are rated at 12.5 volts according to manual,i wont mess with the subs i know that not even if they were free i hate them but there so darn cheap that should tell u somethang |
Silver Member Username: •cam•
Post Number: 754 Registered: Nov-06
| Posted on Sunday, September 30, 2007 - 08:36 pm: |
If you want 1200W (underrated) continuous power at 1 ohm, and 12.5V, get an eD NINe.1. Especially if you were thinking of paying retail for that a-burn. |
Tn
Us
Post Number: 109 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 08:55 pm: |
idc if its underrated.if it puts out 1200 rms at 14.4 volts im happy.and im not paying retail for it,i can get a refurb for 200 dollars with a year warranty |
Post Number: 756 Registered: Nov-06
| Posted on Sunday, September 30, 2007 - 09:32 pm: |
I dunno. From what I've heard Hifonics is a little better, if you wanna go that cheap. B-stock NINe.1s are $275. I'm pretty sure they come with the 5 year warranty. Way better quality. Up to you of course, but it's better to save a for a little now, instead of buying a POS then buying something good later, when you could have just bought something good in the first place. http://www.edesignaudio.com/edv2/product_info.php?products_id=372 |
Tn
Us
Post Number: 110 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 09:38 pm: |
ive heard somebody had one of them and it gave out in 2 days and they wouldnt take it bak,i kno how cheap stuff goes i had kenwood b4.right now i got a mtx but want a little more power |
Post Number: 760 Registered: Nov-06
| Posted on Sunday, September 30, 2007 - 09:48 pm: |
They seem to have gotten waaaayyy better. Haven't heard any horror stories for a long while. They've been good to me. |
Tn
Us
Post Number: 111 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 09:56 pm: |
idk every company has bad and good stuff,most companys u pay for the big name,i may end up getting a pos but.i get a refund if i dont like it within 30 days,some ppl have been running audiobahn amps for years and years.but i wouldnt have there subs no way in hell they dont even hit every note,oh & believe me if it aint doing what it says it will not be used it a be sent back |
Tn
Us
Post Number: 112 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 10:16 pm: |
i might get that amp,would need 2 more subs tho according to somebodys test,1500 watts at 13.7 volts,gd |
Tn
Us
Post Number: 113 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 10:18 pm: |
whats class b tho,the one i loked at on the site without using that link was like 350 dollars |
Silver Member Username: Imalik
SD2.5......ED9.1=Boom,
New Jersey
Lord Protect...
Post Number: 550 Registered: May-06
| Posted on Sunday, September 30, 2007 - 10:23 pm: |
B stock 9.1 will have a 1 yr warranty, New 5yrs |
Tn
Us
Post Number: 114 Registered: Sep-07
| Posted on Sunday, September 30, 2007 - 10:26 pm: |
is it a refurb |
Gold Member Username: Carguy
Post Number: 6497 Registered: Nov-04
| Posted on Monday, October 01, 2007 - 09:43 am: |
The Audiobahn HCT series do put out. I've used and tested the 2300 series last year. If used properly, it'll perform well. It's not like Hifonics, the power numbers are there as stated. It is not however that durable, meaning, if the amp says 4ohms, then do not hook up 2ohms, nor crank up the gain/level to get more bass. If you do, the amp will blow. Other than that, I'd say it's quite good, same goes for DUB series as well. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4939 Registered: Dec-05
| Posted on Monday, October 01, 2007 - 08:27 pm: |
i agree with isaac, the're just sensible amps but do rated power. I think that line is A/B which means high consumption |
