Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp voltage?
Author Thread: Amp voltage?
Username: Aqua_acura
Post Number: 11
Hi, I've never worked with digital amps before, as well as the fact that I have a new headunit. The owner's manual states that the voltage clips at 4v, so that means I set the amp anywhere below 4v? The reason it confused me was that the lower the voltage, the louder the bass, so I was a little confused. Thanks.
Post Number: 12
bump
Username: •cam•
Post Number: 738
maybe that's the max input voltage from your deck?
Username: Nd4spd18
Northwest PA
Post Number: 3255
Dont go by the output of the HU. Use this info to set your gain:
http://www.subwoofertools.com/forum/setgain.asp
http://mobile.jlaudio.com/support_pages.php?page_id=143
Post Number: 13
Alright, don't really have a digital multimeter or anything fancy...thanks for the links though. Is there any "dangerous" voltage? Would it be better to set the volts lower or higher (settings are for 0.1-0.5, 1.5, 2.5, 4, and 8 volts)?
Username: Somedonniedude
Post Number: 294
Set the voltage input on your amp the same as your voltage output on your head unit. What kind of HU do you have?
You can get a digital multimeter at walmart for cheap, and they are very usefull.
Post Number: 14
I have an Alpine CDA-9885, and for an amp I have an Alpine MRD-M1005.
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp voltage? [ « Previous ] [ Next » ]
