Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > Good components?
Author Thread: Good components?
Username: Djhasanicesoundsystem
Vista, Ca
Usa
Post Number: 155
ok im am trying to get some component speakerrs for my 98 ford escort. the size i need are 5.25" in the front and 5x7's in the back. what are some good speakers for cheap and a good amp to run them?
thanks DJ
Username: Kaerfpl
Spencerport, NY
Post Number: 604
I have these in my car right now and they have very good highs and pretty decent bass:
http://www.sonicelectronix.com/item_8914_MB+Quart+EKA+113.html
Ive heard these Alpines awhile back and they sounded pretty good:
http://www.sonicelectronix.com/item_3453_Alpine+SPR-57LP.html
If your willing to spend more money, you could get some better stuff.
Username: Kaerfpl
Spencerport, NY
Post Number: 605
If you really wanna run an amp, try this:
http://www.sonicelectronix.com/item_3579_Kicker+KX200.4.html
Vista, Ca
Usa
Post Number: 156
cool man thanks. ya and i like the money im gonna spend on these. but ya are these the only ones you suggest?
Username: Kaerfpl
Spencerport, NY
Post Number: 610
no, these are just the cheapest that I found, I'll post some more when I get out of school.
Vista, Ca
Usa
Post Number: 157
ok well im thinking between these 2
PHOENIX GOLD r5.0comp 5.25 5 1/4 COMPONENT CAR SPEAKERS
and
Brand New MB Quart EKA 113 5-1/4" 80W 2Way Car Speakers
do you think these would both sound good on the kicker amp you showed me? or should i run it off
Kicker ZX350.4 4 Channel Amplifier, KICKER ZX200.4
Username: Kaerfpl
Spencerport, NY
Post Number: 615
This would sound better than the PG:
http://www.sonicelectronix.com/item_4294_Infinity+Kappa+50.7CS.html
Those MB Quarts are awesome and for the price ou can't beat them.
If you were to pick the Infinities I listed, then I would just run this amp: http://www.sonicelectronix.com/item_2096_Kicker+KX200.2.html to the Infinities and keep the MB's on the HU power supply. Or you can run that ZX350 to all four. All up to you!
Home > Message Board > Car Audio > Speakers > Archive through November 14, 2007 > Good components? [ « Previous ] [ Next » ]
