Thread: Amp help |
Bronze Member Username: Ghavens1981
Lexington ,
Ky
United states
Post Number: 20 Registered: Sep-07
| Posted on Wednesday, September 26, 2007 - 01:17 am: |
is there some kind of a general setting for the gain on an amp mine is turned up about 3/4 of the way is this to high |
Silver Member Username: Kpa2727
Post Number: 650 Registered: May-07
| Posted on Wednesday, September 26, 2007 - 07:03 pm: |
yes, get a multi meter, dissconnect sub woofers. burn a 50 hz test tone to cd from www.realmofexcursion.com find out your amp's voltage here http://www.subwoofertools.com/forum/setgain.asp now remove the subs, put the meter on A.C. VOLTAGE and the subs terminals and with the radios volume 45 percent of the way up and the test tone playing set your gain to the voltage u got from the calculator above. when done your all set, reconnect the subs. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3249 Registered: Jul-06
| Posted on Wednesday, September 26, 2007 - 08:21 pm: |
^^^^ Do what he said, except use 75% volume. Thats safe on pretty much any HU. |
Lexington ,
Ky
United states
Post Number: 21 Registered: Sep-07
| Posted on Wednesday, September 26, 2007 - 11:01 pm: |
thanks thats very helpful where can i buy a voltage meter |
Silver Member Username: Dannyboyy
O/S Power!!!!,
i lo...
Post Number: 465 Registered: Jun-06
| Posted on Wednesday, September 26, 2007 - 11:09 pm: |
walmart has them buy a Digital Multi Meter and it should have a setting for ac voltage |
Lexington ,
Ky
United states
Post Number: 22 Registered: Sep-07
| Posted on Thursday, September 27, 2007 - 12:11 am: |
thanks you know roughly how much |
Bronze Member Username: Thunderb
Post Number: 51 Registered: Sep-07
| Posted on Thursday, September 27, 2007 - 12:14 am: |
5-10 dollars |
Lexington ,
Ky
United states
Post Number: 23 Registered: Sep-07
| Posted on Thursday, September 27, 2007 - 04:11 pm: |
thanks |
