Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp to power Vega Stroker 124?
Author Thread: Amp to power Vega Stroker 124?
Username: Karlmalone
So basically I have this Cerwin Vega Stroker 124 (4 ohm DVC) and I need an amp to power it properly. RMS handling is 2000 watts so I am looking for something around there to get some serious output. My budget is $500-600 so what would be suggested?
Username: Chaunb3400
Huntsville, Alabama
U.S.
Post Number: 12876
so an amp that will do 2000rms @2ohms... Look for a Kicker ZX or KX 2500.1
That amp is rated at 2500rms, wouldn't that damage the sub?
Are Alphasonik amps worth considering or are they not so good?
Also I need something that will accept a 4g wire or larger. I was looking at those Hifonics amps because the numbers look really good but after reading some commentary on here I am looking for something else.
Are MMATS amps still high quality or have they also gone to hell?
Huntsville, Alabama
U.S.
Post Number: 12879
"That amp is rated at 2500rms, wouldn't that damage the sub?"
noooo, u should be fine...just set ur gains,eq's,etc. correctly and u will be fine
also ur gonna need 0ga wire, 4gauge wire is 2 small for that much current...
Hifonics and Alphasonik are both really questionable amps....Personally i wouldnt get either one of them...Ask for MMats they still have decent stuff...
Username: Juliob
Santo Domingo
Dominican Re...
Post Number: 4927
that's true
i actually have 0 gauge wire but the kicker amps are listed as having smaller terminals, so do i just use an adapter to make it fit into the amp or what?
Home > Message Board > Car Audio > Amplifiers > Archive through October 15, 2007 > Amp to power Vega Stroker 124? [ « Previous ] [ Next » ]
