Thread: Alt help |
Silver Member Username: Holt_champ
Htown,
MI
Post Number: 862 Registered: Oct-06
| Posted on Monday, September 24, 2007 - 09:33 pm: |
what size alt should i get to run a 2600wrms system. i did have a 200 amp in my grand am but it didnt work that great.im geting a 03 monte carlo, do they make anything larger than a 200 amp alternator for those cars?? anymore suggestions?? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3224 Registered: Jul-06
| Posted on Monday, September 24, 2007 - 10:26 pm: |
The biggest you can get. 200 amp should work though. I'm running a 3000 watt amp on a 200 amp alt and a 1500 amp Odyssey battery. Works good. |
Htown,
MI
Post Number: 866 Registered: Oct-06
| Posted on Monday, September 24, 2007 - 10:54 pm: |
well i had 200 amp in my grand am with 2 optima batteries. the voltage dropped really bad. does it have anything to do with what kind of car? i know grand ams are kinda poor quality. |
Northwest PA
Post Number: 3236 Registered: Jul-06
| Posted on Monday, September 24, 2007 - 11:17 pm: |
Could have been a wiring issue. Mayble the big 3 wasnt done right, sometihng along those lines. IDK |
Htown,
MI
Post Number: 867 Registered: Oct-06
| Posted on Tuesday, September 25, 2007 - 12:14 am: |
is there a way to check how many amps the alternator really is?? |
Northwest PA
Post Number: 3239 Registered: Jul-06
| Posted on Tuesday, September 25, 2007 - 01:34 pm: |
Yeah but you need some expensive equipment to do it. |
Htown,
MI
Post Number: 868 Registered: Oct-06
| Posted on Tuesday, September 25, 2007 - 11:27 pm: |
are there any places that can or will do it? |
Northwest PA
Post Number: 3246 Registered: Jul-06
| Posted on Wednesday, September 26, 2007 - 08:13 pm: |
Not that I know of. Auto parts stores say they can but they don't do it right. |
