Thread: Should i get a Hifonics Bxi2006D or Soundstream pca2000d |
Silver Member Username: Timothy_314
Post Number: 316 Registered: May-06
| Posted on Monday, September 24, 2007 - 05:46 pm: |
i cant decide witch one what do you guys think Hifonics Bxi2006D or Soundstream pca2000d and do you know of any good websites that i could order one of them amps at? |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3228 Registered: Jul-06
| Posted on Monday, September 24, 2007 - 10:36 pm: |
Between those, i would get the Hifoncis but be aware they are overrated by 20% |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5061 Registered: Jul-06
| Posted on Tuesday, September 25, 2007 - 08:42 am: |
"Between those, i would get the Hifoncis but be aware they are overrated by 20%" 20 percent...where did you get that info from M.S? |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4925 Registered: Dec-05
| Posted on Tuesday, September 25, 2007 - 01:57 pm: |
Between those, i'd choose soundstream, 1875W rms at 1ohm tested :p |
Northwest PA
Post Number: 3240 Registered: Jul-06
| Posted on Tuesday, September 25, 2007 - 04:17 pm: |
That is not an exact measurement but an estimate..... its common knowledge that Hifoncs Brutus amps do approximately 80% of the power they claim, in other words overrated by 20%. |
Post Number: 317 Registered: May-06
| Posted on Tuesday, September 25, 2007 - 07:28 pm: |
i know some where, where i can pick up that Soundstream pca2000d for $550 no tax but you guys think the Hifonics is better? i like the soundstream looking at the watts it looks better down to "1100 Watts x 1 Channel @ 4 Ohms" rather then "1 x 650-Watts RMS @ 4-Ohms" |
Northwest PA
Post Number: 3241 Registered: Jul-06
| Posted on Tuesday, September 25, 2007 - 09:28 pm: |
Damn thats way too much for an amp like that. Look at the price of the hifonics on ebay. Hell, I paid less than that for my American Bass VFL-200.1, and thats a 3000 watt amp with great quality. |
Post Number: 318 Registered: May-06
| Posted on Thursday, September 27, 2007 - 12:35 am: |
so you guys don't think i should get the Soundstream? |
Bronze Member Username: Vash3000
Post Number: 57 Registered: Nov-06
| Posted on Thursday, September 27, 2007 - 02:41 pm: |
I dont know if this is true or not but I heard Soundstream's new line of amps like that PCA2000 model that you mention, they are junk. They arent as good as built as compared to old school soundstream which was made in USA. I also heard from an audio installer that the Soundstream PCA3500 model burned up if you feed it less than 14 volts. The amp literally fried and they had to send it back for a new one. But im not sure if thats on all the PCA models. And for $550 you mite want to consider something else thats way better and cheaper. |
Platinum Member Username: Rovin
4 10 Pioneer...
Post Number: 12254 Registered: Jul-05
| Posted on Thursday, September 27, 2007 - 11:23 pm: |
alot of companies there new stuff is not as good as long ago & yes SS is 1 of them i do own that same 2000d SS amp & its master\slave switch is giving problems\became loose since my set is tuned for the lows & i have a feeling it shook up my amp internals even though amp is at least 16" away the SS 3500d - well it was found out not long after it came out that its power supply wasnt good so they completely stopped producing that model if i had to buy now i would try the Hif instead since their both around the same price & http://onlinecarstereo.com/ has good price with free s\h too ..... |
Post Number: 319 Registered: May-06
| Posted on Sunday, September 30, 2007 - 09:18 pm: |
aight thanks guys im probably gonna get the Hifonics now |
Silver Member Username: Kpa2727
Post Number: 666 Registered: May-07
| Posted on Tuesday, October 02, 2007 - 07:03 am: |
i got the 1606 d hifonics brutus and it was a bit of hit and miss to tune but i figured it out and it sounds real nice. get it at caraudio.com with free shipping and warrenty like i did real cheap u'll be satisfied enough. |
