Thread: Alternater |
Bronze Member Username: Ghavens1981
Lexington ,
Ky
United states
Post Number: 15 Registered: Sep-07
| Posted on Monday, September 24, 2007 - 04:33 pm: |
who do i need to talk to or where do i need to go for a bigger alternater |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5048 Registered: Jul-06
| Posted on Monday, September 24, 2007 - 06:22 pm: |
Iraggi alts can be found on Ebay or Excessive amperage.There's also Ohio Generators but I hear a lot of bad things about them.There's lots of options depending on what kind of car you have. |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 3225 Registered: Jul-06
| Posted on Monday, September 24, 2007 - 10:29 pm: |
Ohio Gen are very good but expensive. Iraggi alts are good, So are DB electrical. They often have the best price too, but they're only for american vehicles. |
Post Number:...
Post Number: 5068 Registered: Jul-06
| Posted on Tuesday, September 25, 2007 - 02:27 pm: |
I've heard tons of bad stories about Ohio Gen though...I've never run one personally but I a couple guys from CA.com said they put Ohio Gen alts up against Iraggi alts rated for the same amperage and the Iraggi alts absolutely destroyed the Ohin gen alts. |
