Thread: Amp for Kicker L7 Solo-Baric |
New member Username: Blackonblackhonda
Post Number: 5 Registered: Jun-07
| Posted on Sunday, September 23, 2007 - 08:48 pm: |
Hey guys! Just dumped my two 12's and got a solobaric. its a 4ohm. what subs do u reccomend. im thinking a monoblock for sure. but idk what the difference is when two amps say 1000 watts but ones 300 and the other 700. so any suggestions on what ones. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4917 Registered: Dec-05
| Posted on Sunday, September 23, 2007 - 11:12 pm: |
you need to look at RMS ratings and brands, cuz they all lie, any questions you come here and post, cuz we can help you out. If your sub is a 15 DVC 4 ohm L7 grab a kicker ZX 1000.1 and you're done. |
Post Number: 6 Registered: Jun-07
| Posted on Monday, September 24, 2007 - 10:12 am: |
its a 12" dvc. i know i could go with the kicker but those are pretty expensive arent they? |
Post Number: 4920 Registered: Dec-05
| Posted on Monday, September 24, 2007 - 10:32 am: |
well.. if that's a 12" sub you need 750w rms at 2 ohms, you can get a kicker zx 750.1, if you can't afford it, then grab a Power acoustik a1000db, it will work, trust me. |
New member Username: Qx42nv
Post Number: 2 Registered: Sep-07
| Posted on Monday, September 24, 2007 - 10:54 am: |
i have the RF power 800a2 old school amp pushing my 1 12 kicker L7 sounds very clean and bumps hard...but i keep blowing the fuse for the amp... |
Post Number: 7 Registered: Jun-07
| Posted on Monday, September 24, 2007 - 09:29 pm: |
The power acoustick is def affordable but will it end up taking a big dump on me? |
Silver Member Username: •cam•
Post Number: 704 Registered: Nov-06
| Posted on Monday, September 24, 2007 - 09:45 pm: |
i've heard that they're "built like tanks". aXXXXdb series as least. |
Post Number: 8 Registered: Jun-07
| Posted on Monday, September 24, 2007 - 10:46 pm: |
ok so 175 sounds pretty darn good to me for an amp. think i should give that one a try? |
Post Number: 4930 Registered: Dec-05
| Posted on Tuesday, September 25, 2007 - 02:15 pm: |
Cam, they're not like a tank, but for the money, comparing the market, they're a tank lol! Aaron, you should try it, you won't loose anyway. |
Post Number: 9 Registered: Jun-07
| Posted on Tuesday, September 25, 2007 - 10:07 pm: |
ok ill give it a try. any sites u would recomend me to? |
Silver Member Username: Cblaze
Tn
Us
Post Number: 102 Registered: Sep-07
| Posted on Thursday, September 27, 2007 - 11:09 pm: |
www.sonicelectronix.com |
Post Number: 10 Registered: Jun-07
| Posted on Saturday, September 29, 2007 - 01:50 pm: |
hey. so i was lookin at that sonic electronix site. i saw some audiobahn refurbished amps for pretty cheap. are they any better quality then the power acoustik |
