Thread: JL Audio 1000/1...Will the 12w7 be good with it??? |
New member Username: Schmidtyy206
Post Number: 1 Registered: Sep-07
| Posted on Saturday, September 22, 2007 - 07:13 pm: |
I have a JL Audio 1000/1 amplifier and trying to figure out what subwoofer will go best with it? Will one 12w7 be good with it? or the 13w7? I know that the 12w7 runs at 3 ohms which is louder than the 13w7 becuase the 13w7 runs at 1.5 ohms. Also what is a cap? should i get one? What does it do and where can i get it? Thanks anyone for the help in advance. |
Gold Member Username: Naledge503
Http://com4.runboard.c...
Post Number: 1830 Registered: Jun-06
| Posted on Saturday, September 22, 2007 - 09:19 pm: |
First the impedance (ohm) only dictates how you wire things up and what load the amp will read. And secondly the 1000/1 is rated at 1000rms at 1.5ohms-4ohms. |
Post Number: 2 Registered: Sep-07
| Posted on Saturday, September 22, 2007 - 11:22 pm: |
So you can run a 12w7 at 3 ohms on a 1000/1 amp? |
Post Number: 1833 Registered: Jun-06
| Posted on Sunday, September 23, 2007 - 12:02 am: |
Yezzir! |
Post Number: 3 Registered: Sep-07
| Posted on Sunday, September 23, 2007 - 01:26 am: |
What kind of cap should i get for this? |
Post Number: 5 Registered: Sep-07
| Posted on Sunday, September 23, 2007 - 01:34 am: |
And how would i get the 12w7 to run at 4 ohms instead of 3 ohms? |
Post Number: 1844 Registered: Jun-06
| Posted on Sunday, September 23, 2007 - 02:02 am: |
dont need the cap and you cant get the sub to run at 4 ohms. only at 6ohms or 1.5ohms. In your case you will want to wire it to a 1.5ohm load. Do it like this...dont worry about this being for a DVC 4 ohm sub... http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=1DV C%5F4%2Dohm%5Fmono |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 424 Registered: Jul-05
| Posted on Tuesday, September 25, 2007 - 03:37 pm: |
them subs aren't dual voice coils, i think they are all single 3 ohm, so no matter what you do your goin to have a 3 ohm load unless you get 2 and knock it down to 1.5, but it really doesn't matter what ohm it is at with that amp |
Silver Member Username: Demon_pride
Crowder,
Oklahoma
Post Number: 221 Registered: Oct-05
| Posted on Wednesday, September 26, 2007 - 01:59 am: |
The 12W7 and the 1000/1 were built for each other. |
Gold Member Username: Th3pwn3r
Post Number:...
Post Number: 5088 Registered: Jul-06
| Posted on Wednesday, September 26, 2007 - 09:11 am: |
"The 12W7 and the 1000/1 were built for each other." Aww how cute <3 |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 6230 Registered: Jul-06
| Posted on Wednesday, September 26, 2007 - 05:30 pm: |
^^post wh0re....lol +1 for me  |
Gold Member Username: Carguy
Post Number: 6495 Registered: Nov-04
| Posted on Friday, September 28, 2007 - 09:49 am: |
JL 12W7 is a SVC 3ohm sub. So you can't run it at 6ohms nor 1.5ohms. |
