Thread: Help with coaxials. |
Silver Member Username: Alexv305
Tavernier,
FL
Post Number: 601 Registered: Oct-05
| Posted on Saturday, September 22, 2007 - 04:34 pm: |
I need a pair of either components or coaxials. Right now I'm leaning for the coaxials because I have no where to mount tweeters if I get a component set. For under $200 what is the best pair of either components or coaxials that come in the 6-1/2 inch size? Im thinking the Polk MOMO MMC650s (coaxials) or the Infinity Kappa 63.7i (coaxials), but don't know which would sound better in a 2007 Honda Civic. The Polk MOMOs have a single tweeter on each coaxial that swivels up to 15 degrees and the Infinity Kappas have two tweeters on each coaxial, but they dont swivel.. What will sound best? I like my highs to be sharp, crisp, and intense. |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 5079 Registered: Jan-06
| Posted on Sunday, September 23, 2007 - 12:35 am: |
listen to both those are pretty common in like a best buy or something. |
