Thread: Please Help...Need Amp for my Subs! |
New member Username: Mx718
Post Number: 2 Registered: Oct-04
| Posted on Wednesday, September 19, 2007 - 11:45 pm: |
First of all i am a big time rookie so excuse if i ask a dumb question lol...I have (2) Crossfire BMF 1028 subs...I hope are good subs? I am looking for a amp to push these...I dont even know where to start...I had 2 Rockford P450.2 amps hooked up to them one on each sub and the amps kept going into cool down mode and would shut off the subs for about 30 seconds. I got rid of those...someone told me crossfire amps are good? But i dont even know what the ohms mean so i have no clue what to get! Thanks for your help Freddie |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1344 Registered: Mar-06
| Posted on Thursday, September 20, 2007 - 12:10 am: |
Are these subs dual 4 ohm? Look on the magnet and tell us if it has 2 or 4 ohm coils. It should say. Also, what is the rms of these subs. Kevin |
Post Number: 3 Registered: Oct-04
| Posted on Thursday, September 20, 2007 - 12:18 am: |
http://www.crossfirecaraudio.com/prodInfo.asp?IDProduct=216 <<<info page 300 RMS 2 or 8 ohm user switchable |
Bronze Member Username: Moz
Post Number: 29 Registered: Sep-07
| Posted on Thursday, September 20, 2007 - 12:56 am: |
i have a pioneer premier amp, it would over power them but thats good if you want to upgrade someday. im selling it for 350 if your interested email me wakecheer@hotmail.com 2076_310069935_152869107%2C00.html,http://www.pioneerelectronics.com/pna/v3/pg/p roduct/details/0,,2076_310069935_152869107,00.html |
Post Number: 4 Registered: Oct-04
| Posted on Thursday, September 20, 2007 - 09:13 am: |
Someone? Anyone? All i need to know is how to match up the numbers behind the sub with the numbers behind the amp... I have a switchable 2ohm or 8ohm subs so would i need a 1,2, or 4 channel amp. Crossfire make a XP 600.4 and also a mono XP 600.1...which one would be better? Or is there better amps out there? |
Post Number: 5 Registered: Oct-04
| Posted on Thursday, September 20, 2007 - 09:14 am: |
They are 300 RMS each...2.5" 4 Layer coil...85oz. magnet |
Post Number: 30 Registered: Sep-07
| Posted on Thursday, September 20, 2007 - 11:00 am: |
they are subs so i would get a mono amp if they are 300 rms each you would want a 600 watt rms amp. run it in 2 ohm i take it they are single voice coil if they can be run at 8 ohm |
Post Number: 6 Registered: Oct-04
| Posted on Thursday, September 20, 2007 - 01:06 pm: |
yea it dont say anything about dual voice coil. So the 600 amp the way to go? Is there any one that is better than the rest or should i stick with the XP crossfire |
Post Number: 31 Registered: Sep-07
| Posted on Thursday, September 20, 2007 - 02:05 pm: |
personally i would stick with a mono amp and like it says 600 Watts thats probably peak you would want something with 600 rms mono or 2 channel } |
Silver Member Username: Somedonniedude
Post Number: 267 Registered: May-07
| Posted on Thursday, September 20, 2007 - 05:42 pm: |
That sub has to be a D4 ohm. That rockford amp is only 4ohm stable bridged (assuming it was bridged) and you were probobly running it @ 2 ohm. Also in that link you posted, it says either 2 or 8 ohm and thats only for 1 sub. The only way you can switch up ohm loads on a sub is if it has more than 1 coil. So saying if all that i just said is true, you need a mono amp that will do at least 600wrms @ 1 ohm or 4 ohm. If you get a 2 channel amp, make sure it will do at least 300wrms x2 @2 ohms, 600wrms x1 @ 1 ohm, or 600wrms x1 @4 ohm. |
Post Number: 269 Registered: May-07
| Posted on Thursday, September 20, 2007 - 06:03 pm: |
If you would be interested in a rockford p6002 amp, I have one for sale. Will do 600rms@ 4 ohm bridged, 300rms x2 @ 2 ohm. If your subs are dual 4 ohm, this amp would work. |
Bronze Member Username: Ques07
Post Number: 22 Registered: Sep-07
| Posted on Friday, September 21, 2007 - 02:11 pm: |
what they mean by dvc... on the sub you either have on pos one neg or 2 pos 2 neg... so if you look at the back of the sub then you will know if it is dvc or single... because he is a noobie... and the subs are single voice coil...from what i read... he has 2 of those subs... and together they are 2 or 8 ohm... i would get a 2 ohm amp... try a kicker 750.1... it's 750 but actually around 890 rms at 2 ohms so keep them down or it will blow your subs |
Post Number: 23 Registered: Sep-07
thatt will allow you to upgrade when you want better subs too... |
Silver Member Username: Press1
Yuba City,
CA
Post Number: 194 Registered: Nov-04
| Posted on Friday, September 21, 2007 - 02:39 pm: |
If you read the spec sheet on them, they have to have Dual Voice Coils, but they have that plug on them to make it into either an 8ohm sub or a 2ohm sub...meaning it would be a dual 4ohm. If you have two of these subs, and you set the plug in device on the sub to 2ohms you will either need a 4ohm 600wrms amp, or a 1ohm 600wrms amp. Depending on if you wire it series or parallel to the amp. http://www.the12volt.com/caraudio/boxcalcs.asp#par Arrow down till you see the calculators for series and parallel...it also gives a good diagram of the wiring. |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4910 Registered: Dec-05
| Posted on Friday, September 21, 2007 - 02:47 pm: |
you need 600w rms at 1 or 4 ohms, i'd look for a JL 500/1 or another good brand like RD audio or Sundown. |
