Thread: MMATS Pro Audio PRO641 3-way Component |
Gold Member Username: Loc_out
Santa Ana,
Ca
Resonant Eng...
Post Number: 1141 Registered: Feb-05
| Posted on Tuesday, September 18, 2007 - 12:14 pm: |
Okay i am thinking of upgrading my components. Currently i have some Diamond Audio D661S. They are rate at 90rms. Would those mmats sound louder and cleaner? or should i just buy some Diamond audio hex? |
Gold Member Username: Adddisorder
West palm,
Florida
Post Number: 5069 Registered: Jan-06
| Posted on Tuesday, September 18, 2007 - 07:44 pm: |
mmats are really nice. i think chad is running those? or a similar set anyway. if you really want to go with a 3way set then go for it or if you can get a good deal on a mmats 2way set. |
Santa Ana,
Ca
Resonant Eng...
Post Number: 1143 Registered: Feb-05
| Posted on Wednesday, September 19, 2007 - 12:50 pm: |
Chad has a similer i think his only diff is his mid-range is a 5 1/2. I hear his and i really like them. That's kind of the reason why i am looking on buying some. |
Platinum Member Username: Bestmankind
-apem
Post Number: 15295 Registered: Oct-05
| Posted on Monday, September 24, 2007 - 12:10 pm: |
yep i have the one with the 651 pro series. chad geary will hook it up for you with the price. i really love my speakers. the highes aren't too harsh and the mid and mid bass really comes alive. also the mmats 6 x 9 i have really compliment the front statge. |
Gold Member Username: Bernymac
BME
Post Number: 3324 Registered: Sep-04
| Posted on Monday, September 24, 2007 - 09:29 pm: |
and I really love my memphis components  |
Santa Ana,
Ca
Resonant Eng...
Post Number: 1160 Registered: Feb-05
| Posted on Tuesday, September 25, 2007 - 11:16 am: |
Check it out i saw this and i was thinking it wouldnt be a bad idea to upgrade. http://cgi.ebay.com/MMATS-Pro-Audio-PRO641-3-way-Component-System_W0QQitemZ23017 3553489QQihZ013QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem I called chad and asked him from a price on the mmats 2100.1 but he said he would have to call to get a price on it. Berny when i hear your truck last you had some CDT's right? I love the way your mid bass hits and the fact your highs arent harsh. Who installed them for you Chad? |
BME
Post Number: 3328 Registered: Sep-04
| Posted on Thursday, September 27, 2007 - 01:44 am: |
Yeah I had the CDT's. Now I have the Memphis MSYNC6 w/ titanium tweeters. I like them better than my CDT's though. The CDT's started to get dull after 30/40 volume. With the memphis components. I can go past 30 and they just keep getting louder while retaining good sq. |
Santa Ana,
Ca
Resonant Eng...
Post Number: 1184 Registered: Feb-05
| Posted on Thursday, September 27, 2007 - 10:25 am: |
I'll be going over to Chad's shop something next month maybe we can't chill or something. I want to hear your memphis. |
