Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Which Would Be Better...
Author Thread: Which Would Be Better...
Username: Kaerfpl
Spencerport, NY
Post Number: 541
Which Amp Would be a better choice for powering a 1200 Watt system?
Hifonics BXi 1606D: 1600 Watts @1ohm
Ed NINe.1: 1200 Watts @1ohm
MA Audio HK1998: 1200 Watts @1ohm
Orion HCCA-D2400: 1200 Watts @1ohm
Can't really find anything else...If there's something you know that would be better for around $300 please let me know.
Username: Kaerfpl
Spencerport, NY
Post Number: 542
Scratch that MA Audio amp, it's not stable at 1ohm
Username: Carguy
Post Number: 6480
I'd go with Orion first, then the rest.
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 21
if you found the Orion for around $300, thats a he11 of a deal! Go with that best quality --then hifonics
Username: Nissankicker
Grambling, LA
Post Number: 138
Go on EBAY... Type in -> Kicker KX1200.1 <- I believe there are 2 on there for $300 each.
Username: Kaerfpl
Spencerport, NY
Post Number: 544
the only question I have about the Hifonics is that does it really put out what it's rated? I've been hearing that the new line of amps arn't putting out whats rated so I don't know if it would stand up to my subs which would be 2 RE SE at 600 Watts RMS each.
Username: •cam•
Post Number: 663
the eD should do a solid 1400 on a good charging system.
Username: Th3pwn3r
Post Number:...
Post Number: 4943
There are 2 Hifonics 1200 watt amps going for a very cheap price on caraudio.com you should use the search feature and you'll find them fast.That's what I would do if I were looking into a small system for cheap.
Username: Chevysitinsideways
West suffield, Connecticut
Usa
dont look for wattage look for RMS and i would not go with any of these at 1 ohm there not stable look for 2 ohm like rockford fosgate makes nice high end stuff.
Username: Thunderb
Post Number: 22
yamaharider all those amps are 1 ohm stable.
Any of those amps will be fine for what you are doing as long as you get the ohm load right.I would go with the orion over anything else on that list then the ED NINe
Heres what I just bought and its rock solid.
http://cgi.ebay.com/PLANET-AUDIO-1250-WATT-CLASS-D-MONOBLOCK-AMPLIFIER_W0QQitemZ 190154063771QQihZ009QQcategoryZ64570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Zed audio quality at its best.
If you look around you can find some good quality stuff pretty cheap. Don't get in a hurry and buy the first thing you see.
Username: Kaerfpl
Spencerport, NY
Post Number: 545
"Don't get in a hurry and buy the first thing you see."
Ya, I know what you mean. I looked around for 3 months before I desided what subs to buy which I just got yesterday :-). I really like the Orion amp and I found it for $299 on sonic, brand new so I think I might grab one of those.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Which Would Be Better... [ « Previous ] [ Next » ]
