Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Mazda speed6 with bose system
Author Thread: Mazda speed6 with bose system
Username: Raygib
does anyone have stereo wiring diagrams for this car? I'am tryin to hook up a sub and amp to work with the factory bose....some people say there is a certain way to hook it up because of the bose low signals. 2006 speed6
Username: Thunderb
Post Number: 16
Try looking it up here
http://www.installdr.com/QuickWiring.html
I dont know if they will have the Bose set up but the colors codes should still be similiar as far as the speakers and such from the rear of the deck.
You should be able to go to the rear channel outputs between the factory deck and the factory amp and tie in.Make sure you do not tie in after the amps as this will prolly burn up your inputs on your new amp.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Mazda speed6 with bose system [ « Previous ] [ Next » ]
