Thread: My system?? |
Bronze Member Username: Jtinordi77
Post Number: 20 Registered: Sep-07
| Posted on Friday, September 14, 2007 - 10:46 pm: |
2 Kicker CompVR CVR154 15" 500W RMS Dual 4 Ohm VC Subwoofers A1800DB Power Acoustik 1800W Class D Digital Car Amplifier QPower Dual 15" Slot-Vented Enclosure JVC KD-G120R AM/FM CD Player w/Remote Control KDG120R Was wondering if this amp would power the subs to get maximum performence without blowing them.....will it hit hard??? |
Silver Member Username: Somedonniedude
Post Number: 240 Registered: May-07
| Posted on Saturday, September 15, 2007 - 02:30 am: |
nope. you will only be able to get 600rms aout f that amp with subs vc configuration. Look for an amp that will do 1000rms @ either 4 ohms or 1 ohm. How much are you wanting to spend? If your on a budget, look into hifonics amps. Great bang for your buck. |
Silver Member Username: 2pacalypse1971
Sandusky,
Oh
Post Number: 421 Registered: Jul-05
| Posted on Saturday, September 15, 2007 - 03:12 am: |
i have 2 kicker cvr 15's and they slam, i got them on a mbquartraa1000 so they're each gettin 500 watts ecah, and i have them in some prefab sealed box, i'm just waitin to get a custom one made |
Post Number: 21 Registered: Sep-07
| Posted on Saturday, September 15, 2007 - 10:36 am: |
what is better 4ohms or 1ohms |
Post Number: 22 Registered: Sep-07
| Posted on Saturday, September 15, 2007 - 10:39 am: |
would this do the job for my 2 kicker 15's above Hifonics BXi1206D 1200W RMS Mono Block Class D 1 Ohm Stable Amp |
Post Number: 247 Registered: May-07
| Posted on Sunday, September 16, 2007 - 04:56 pm: |
With ohms, its the way the subs wire up, and depending on how you have them wired will determine how much power you get out of your amp. If you found an amp that would put out 1200wrms @ 4 ohms, then it would work fine with your subs (coils wires series, subs parallel to amp). But that wont be necessary to look for an amp like that. so in this case you would need an amp that will put out 1200wrms @ 1 ohms (both subs and all coils wired parallel to amp). Check out this link and mess around with the diagrams a little. It will help you understand it all a little better http://rockfordfosgate.com/rftech/woofer_wizard.asp The bxi1206 will work, but hifonics amp are little overated so expect for about 1100rms about of that amp. Still a good amp though and will push those niceley. |
