Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Quick easy question..
Author Thread: Quick easy question..
Username: Ques07
Post Number: 16
the only reason i am posting this question is because i didn't know if there was any other way to do this... but i have a kicker pk1 wire kit which 1/0 gauge... simple enought... it has 2 distribution blocks... one for ground one for power... and a 300a fuse... here is the very simple question.. the 1/0 wire doesn't fit in the wholes...i'm just making sure there is no other way... do i have to cut wire off to get it to fit or is there another way to compress the wire more... the reason doe asking is i don't want to cut wire off when there is a possible way of preventing that:-)
Username: Ques07
Post Number: 17
anyone going to answer or should i just do what i think i should do and just clip the wire to fit... lol
Home > Message Board > Car Audio > Accessories > Archive through November 17, 2007 > Quick easy question.. [ « Previous ] [ Next » ]
