Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Basic 4 channel Amp for new car
Author Thread: Basic 4 channel Amp for new car
Username: A3forme
Post Number: 420
I'm looking for suggestions for a good solid 4 channel amp. Bought a new Chevy HHR and the base stereo is WEAK in comparison to my Honda. This car will not a have a sub installed, just want to upgrade stock speakers and power them properly.
I plan on using MA Audio HK65s. That decision is firm. I've used them, I like them for the money. Just want a reputable brand that puts out 50+ RMS to each channel @ 4ohm. I've been out of the car audio loop for a while so don't know what's good anymore.
Thanks.
Username: •cam•
Post Number: 658
I like my Elemental Designs NINe.4 personally. Works great, 65w to each channel. There's always old school PG and PPI for sale where where I live so you could check your local used listings.
NINe.4 $245
http://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=46
B-Stock NINe.4 $175
http://www.edesignaudio.com/edv2/product_info.php?products_id=375
Username: A3forme
Post Number: 421
Anyone else?
Username: Thunderb
Post Number: 7
You can get a good planet audio amp on ebay for 60-70 bucks. They are made in the usa by zed audio.Anyone who has every owned any amps made by zed will tell you they are the best of the best.
Username: N2audio
Lawrence, Ks
Post Number: 1388
Decent (budget) Profile AP1040
Good -
RF P4004
Alpine MPR-F450
MTX TA3404
Better -
Pioneer Premier PRS-D4100F
MTX TA5604
Username: A3forme
Post Number: 422
How about a RF P450.4 for $155 shipped? 60w X4 @4ohm
Username: Th3pwn3r
Post Number:...
Post Number: 4942
Mazdaman,I know exactly what would fit your bill reliably and cheaply.Go on Ebay and look for the company or seller Hifisoundconnection and look into a Kicker KX350.4 refurbished amplifier.It will run you a bit over 100 dollars and will come with a 3month warranty that IS honored by Kicker.That little amp will put out 60watts RMS x4 at 4ohms.It's a good strong little amp and is very easy on the wallet.I recommend it highly at the price.
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > Basic 4 channel Amp for new car [ « Previous ] [ Next » ]
