Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > How do i match RMS of Subs and Amp?
Author Thread: How do i match RMS of Subs and Amp?
Username: Jtinordi77
I have two 15" Power Acoustik PW3-15H 900W RMS Dual 2 Ohm Voice Coil Subs and i wanted to know if i would double the RMS and get an amp the could handle 1800 RMS or just 900 RMS, if you have any suggestions on amps please let me know!
Also would i use a mono amp or 2 channel amp and what Ohms should i wire them too? Thanks
Username: Hurricanebr1an
Western Burbs of Chicago, IL
Usa
Post Number: 9
1800wrms at 2 ohms is what you want to find in an amp. or somewhere near that but dont overpower them.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DV C%5F2%2Dohm%5Fmono
i would recommend a kicker zx1500.1
one can be had for $380 at hifisoundconnection refurbied.
with that much power, have you done the Big 3 and upgraded your alternator?
most alternators can only handle 1000wrms before needing an upgrade
No i havent upgraded my alternater yet
Home > Message Board > Car Audio > Amplifiers > Archive through September 21, 2007 > How do i match RMS of Subs and Amp? [ « Previous ] [ Next » ]
