Thread: Rockford Amps any good? |
New member Username: 94_toy
Post Number: 3 Registered: Sep-07
| Posted on Thursday, September 13, 2007 - 02:08 am: |
So i got a 12" kicker L5 D4ohm and im loookin for an amp will a RF P300.1 be a good choice cause i can get one off my buddy for $60. The specs say 452 W RMS @ 2 ohhm will that be enough for this 600W RMS amp??? |
Gold Member Username: Jkidder
IA,
DP
RD
Post Number: 1935 Registered: Nov-05
| Posted on Thursday, September 13, 2007 - 02:54 am: |
yoursub is dual 4 ohm so it would wire to 2 ohm. look for 500-800 @ 2 ohm |
Silver Member Username: Somedonniedude
Post Number: 225 Registered: May-07
| Posted on Thursday, September 13, 2007 - 07:17 pm: |
Hook it up and see how it sounds. It wont be enough to push it to its limits, but hook it up and see if you like it. |
Bronze Member Username: Homeboi88
Lexington ,
Kentucky
United states
Post Number: 62 Registered: Apr-07
| Posted on Thursday, September 13, 2007 - 08:15 pm: |
man u need lil bit more power than that check out the kicker zx1000.1 one that should be good for them |
