Thread: HIFONICS BXI1606D |
Bronze Member Username: Ts0uthern5980
Post Number: 18 Registered: Aug-07
| Posted on Tuesday, September 11, 2007 - 07:48 pm: |
is that a good amp for 1200 wrms at dual 2 |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 12822 Registered: Jul-05
| Posted on Tuesday, September 11, 2007 - 11:57 pm: |
nope |
Post Number: 19 Registered: Aug-07
| Posted on Wednesday, September 12, 2007 - 02:10 am: |
then what is |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 6081 Registered: Jul-06
| Posted on Wednesday, September 12, 2007 - 02:23 pm: |
how many threads are you gonna make with the same question? |
Post Number: 25 Registered: Aug-07
| Posted on Wednesday, September 12, 2007 - 02:28 pm: |
as manyas i can till i get a freakin answer |
Gold Member Username: Loc_out
Santa Ana,
Ca
Resonant Eng...
Post Number: 1108 Registered: Feb-05
| Posted on Wednesday, September 12, 2007 - 04:21 pm: |
You are getting answers. That amp isnt good. Get the kicker refur or Chauncey. |
Silver Member Username: Kklagge
San Diego
Post Number: 504 Registered: Dec-04
| Posted on Friday, September 14, 2007 - 07:39 am: |
Nothing wrong with that amp...I'm running one and it works great...running mine @ 1ohm |
Gold Member Username: Juliob
Santo Domingo Dominican Re...
Post Number: 4905 Registered: Dec-05
| Posted on Friday, September 14, 2007 - 04:54 pm: |
they're decent at 1 ohm, that's their strongest output |
Silver Member Username: Somedonniedude
Post Number: 241 Registered: May-07
| Posted on Saturday, September 15, 2007 - 02:39 am: |
tsouthern, did you read all that stuff I posted in one of your last threads? You said you wanted a kicker amp, so look at the refurbished zx1000.1. You've made like 10 threads all the same. Save your self the hassle and get one. Its the best bang for your buck. |
