Thread: Speakers Flatlining HELP!!!! |
Bronze Member Username: Sick96vtecaccord
Va
Usa
Post Number: 22 Registered: Jun-07
| Posted on Monday, September 10, 2007 - 09:04 pm: |
I just bought some new MB Quart Discus Series 6x9's about. 2 weeks ago and they sound excellent. But my problem is that on some of the songs i listen to when the bass is really heavy or drawn out bass notes its causing the speakers to cut out for a few seconds then all the vocals come back. What could be causing this??? 2nd Problem i also have MB Quart components in the front stage an i have noticed recently that when i turn my system up that the vocals get really muffled for a few seconds and then return to normal it does this off and on sporadically. Anyone know what could cause this??? |
Bronze Member Username: Imi4tth3w
San Antonio,
Texas
Post Number: 66 Registered: Feb-07
| Posted on Tuesday, September 11, 2007 - 07:12 pm: |
what are you powering them with? possibly underpowering? |
Bronze Member Username: Moz
Post Number: 15 Registered: Sep-07
| Posted on Wednesday, September 12, 2007 - 01:27 pm: |
i would check your wiring too cause it sounds like some grounds might be touching |
New member Username: Desmo4
Richmond,
VA
Post Number: 2 Registered: Nov-07
| Posted on Wednesday, November 14, 2007 - 04:47 pm: |
Sounds like the amp is clipping. Turn down the volume or get a bigger amp |
Bronze Member Username: Marcooo
Post Number: 26 Registered: Mar-07
| Posted on Wednesday, November 14, 2007 - 05:15 pm: |
or set ur gains properly... |
Gold Member Username: Adddisorder
Palm Beach,
Florida
Post Number: 5455 Registered: Jan-06
| Posted on Wednesday, November 14, 2007 - 06:13 pm: |
set the HPF correctly |
