Thread: Alpine Amp with Kicker Sub |
Bronze Member Username: Peder25
Post Number: 12 Registered: Aug-07
| Posted on Sunday, September 09, 2007 - 12:02 pm: |
I bought an alpine mrd-m1005 amp and have a kicker l7 15 in sub. I heard somewhere that they will not work with each other, that it will end up "clipping" is this true? |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 12778 Registered: Jul-05
| Posted on Sunday, September 09, 2007 - 12:05 pm: |
vc configs on ur sub and spec on that amp? |
Post Number: 13 Registered: Aug-07
| Posted on Sunday, September 09, 2007 - 12:10 pm: |
sub is 1000 wrms and dvc 4ohms, amp is rates 1000 wrms at 2ohms and that is how i plan on running it. |
Silver Member Username: Jesse59672
OKLAHOMA
Post Number: 611 Registered: Feb-07
| Posted on Sunday, September 09, 2007 - 12:33 pm: |
sup chauncey  |
Huntsville,
Alabama
U.S.
Post Number: 12780 Registered: Jul-05
| Posted on Sunday, September 09, 2007 - 12:35 pm: |
they will work 2gether fine..just make sure you set ur gains,eq's,etc correct |
OKLAHOMA
Post Number: 613 Registered: Feb-07
| Posted on Sunday, September 09, 2007 - 12:36 pm: |
why does the subwoofer forum just disappear from time to time? |
Gold Member Username: Nyyfan13
Fi SSD
Post Number: 6041 Registered: Jul-06
| Posted on Sunday, September 09, 2007 - 01:04 pm: |
the admin is going thro it deleting sh1t right now jesse.....it goes down every once in a while |
