Thread: 2 kicker comp cvr12 12" dvc 4 ohms... need amp. |
New member Username: Ques07
Post Number: 1 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 02:49 am: |
i'm just looking for an mono block amp to push these in a custom made closed enclosure with 1.65 cubic ft each compartment... any suggestions? |
Silver Member Username: Evoixmr
Post Number: 117 Registered: Aug-07
| Posted on Sunday, September 09, 2007 - 03:49 am: |
Whats youre budget? |
Post Number: 2 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 03:57 am: |
right around 200... possibly a little less i was lookin at a visonic V918XD... but not sure |
Bronze Member Username: Khae
Post Number: 70 Registered: May-07
| Posted on Sunday, September 09, 2007 - 06:59 am: |
i use to have a set of the same subs u have 2 12 inch kicker cvr dvc and i used my massive audio rs 100 amp to power it... n it pushed it really good.... and i still have the amp if your interted in it.... i have no use for it ne more now since i got a new sub n amp i got a l7 15 inch and a kicker kx 1200.1 amp so yeah... email me if your interted khaesaechao@hotmail.com |
Silver Member Username: B3n07
Louisville,
Ky
Post Number: 292 Registered: Jul-07
| Posted on Sunday, September 09, 2007 - 01:06 pm: |
dude if i was you i would buy a 1200.1 from hifnoics that will give your 12 about 600 rms if you wire them in parrele |
Post Number: 3 Registered: Sep-07
| Posted on Sunday, September 09, 2007 - 03:28 pm: |
from what i know hifonix is overpriced and over rated... any other suggestions??? |
Post Number: 5 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 12:04 am: |
i was also lookin at the POWER ACOUSTIK PS1-3000D... it's rated at 900x1 at 4 ohms... |
Gold Member Username: Ctmike
Ct.
Post Number: 5097 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 12:06 am: |
crap^. just grab a cadence txa1000d for $199 shipped from cadence. |
Post Number: 6 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 12:46 am: |
have you used both of these amps? just wondering because looking at the specs... i would have to wire the subs at 1 ohm to push my kickers enough... |
Ct.
Post Number: 5100 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 12:51 am: |
using the cadence amp right now. no problems with it. budget line of cadence, but it'll power the pair good enough. |
Post Number: 7 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 12:54 am: |
hey email me... scarface732@msn.com... that goes to anyone who has some help for me... i don't mean to be picky but i really want to get an amp to push out whats needed and i don't want to put 400 into 2 kicker 750 amps... |
Gold Member Username: 04redmach1
Columbus,
GA
Post Number: 1320 Registered: Mar-06
| Posted on Monday, September 10, 2007 - 12:57 am: |
Josh Q, if you can go little more thant $200, shoot me an email, I can help you out with a very good quality amp. Kevin lowhz01@yahoo.com |
Ct.
Post Number: 5101 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 01:08 am: |
josh, exactly what is wrong with any of the 3 amps that've been recommended to you so far? and why would anybody really want to waste their time emailing you amps when they can just post recommendations here? and 2 kicker 750 amps, what are you talking about? |
Platinum Member Username: Chaunb3400
Huntsville,
Alabama
U.S.
Post Number: 12793 Registered: Jul-05
| Posted on Monday, September 10, 2007 - 01:12 am: |
buy my ednine.1 1200rms@1ohm at 12.5v...only $245 shipped |
Post Number: 8 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 01:15 am: |
sorry... kicker zx750... i'm trying to wire my subs in parallel so i get 4 ohms... |
Ct.
Post Number: 5102 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 01:16 am: |
any particular reason? you like spending more than you need to? |
Post Number: 9 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 01:18 am: |
4 ohm will give me better quality right? |
Ct.
Post Number: 5103 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 01:22 am: |
you wont notice no difference at all running them at either 4 or 1ohm, except in the price you pay for the amp. |
Post Number: 10 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 01:25 am: |
what about the heat that the amp will be at... 1 ohm will make it alot harder on the subs or amp right... i also want my stuff to last a long time not just burn out in 1 year |
Huntsville,
Alabama
U.S.
Post Number: 12794 Registered: Jul-05
| Posted on Monday, September 10, 2007 - 01:27 am: |
built in fan....never overhearted once... |
Ct.
Post Number: 5104 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 01:29 am: |
do you honestly think everyone that runs a pair of subs at 1ohm have their stuff burn out in a year? do you think a company makes an amp stable at 1ohm knowing that in a year it'll burn out if ran at 1ohm? and if you were that worried about them, why didn't you get a pair of dual 2ohm vc subs to run at 2ohm? running them at 2ohm would have guarranteed you at least 2 years compared to 1 year at 1ohm |
Bronze Member Username: Ques07
Post Number: 11 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 01:45 am: |
yeah i guess... but i'm getting the subs for free in box... so i'm stuck with what i got... but i'm lookin for an amp with a warranty... not used... sorry chauncey ... plus it's a little to much... |
Ct.
Post Number: 5105 Registered: Feb-06
| Posted on Monday, September 10, 2007 - 01:48 am: |
http://www.cadencestore.com/ProductCart/pc/viewPrd.asp?idcategory=125&idproduct= 380 |
Bronze Member Username: Csuho
Nashville,
Tn
Post Number: 46 Registered: Jun-07
| Posted on Monday, September 10, 2007 - 09:31 am: |
i am sorry but that cadence amp is just plain ugly. and it has a lot of empty space on the board too. i am sure they could have made that thing like 10" shorter. but that is a pretty good price on a 1000 watt class d amp brand new with warranty. |
Post Number: 13 Registered: Sep-07
| Posted on Monday, September 10, 2007 - 11:03 am: |
lol i didn't even take al ook at that space is a problem my sub box is going to take up a lot of space in my cav. anything smaller still interested in it though |
